Issues taking off brake rod...
Old Jun 7, 2016 | 12:36 PM
weever82's Avatar
weever82
Default Issues taking off brake rod...
Just making sure my buddy and I are doing this right before I start really cranking on it...
Swapping the stock exhaust on my buddies 13' 48 and need to take off the brake rod to take off the pulley cover to get to the bolts for exhaust brackets...
The Brake rod end by the right foot brake looks to just to held in with a allen screw on that end and a pin/rod on end by rear master cylinder.
My question is that when trying to loosen the screw it doesn't budge.... at all... Is it just a standard bolt and I can just unscrew it...
I know it sounds stupid but really don't wanna strip something or break something over not asking a dumb question.
Thanks guys!
Newbie obviously...
Attached Thumbnails Issues taking off brake rod...-img_4944-1-.jpg   Issues taking off brake rod...-img_4948-1-.jpg
Old Jun 7, 2016 | 12:57 PM
TheHHMF's Avatar
TheHHMF
service manual just says "remove brake rod"
heh good luck
Old Jun 7, 2016 | 01:44 PM
j_bee's Avatar
j_bee
You might find it easier to release the two mounting bolts that hold the front footrest/ brake pedal bracket to the frame and allow it to drop down. If necessary, you can also release the two screws that hold on the rear master cylinder to allow you access to the pulley cover.
The screw in your second picture is a 30 torx and not an allen key I believe. It is held in with Loctite but isn't too big a deal to remove once the footrest assembly is released as you can spin it around to access it better but probably should need to if all you want to do is get the pulley cover off.
If you decide to remove the pin by the master cylinder, take care not to lose the small circlip that holds it in place.
Old Jun 7, 2016 | 01:48 PM
19Sparrow87's Avatar
19Sparrow87
And if you do lose it then be prepared to find out you know more creative uses for the word f*ck then you currently give yourself credit for.
Old Jun 7, 2016 | 04:00 PM
weever82's Avatar
weever82
That's a good idea on dropping it down. I figured just needed to crank down more on it but like to triple check. Appreciate the reply!
Old Jun 7, 2016 | 04:20 PM
WVDevil's Avatar
WVDevil
It should come right out, standard bolt. Not LH thread or anything weird. Maybe try heating it? Some clown might have used red loctite on it.
Old Jun 8, 2016 | 01:03 AM
Troops141's Avatar
Troops141
Yup, mine just came right off, nothing special.. Sounds like it is corroded or somebody put red locktite on it (which would require heat).
Old Jun 8, 2016 | 08:51 AM
weever82's Avatar
weever82
Came home from work and with a little more muscle it popped right off. After that the exhaust was on in 30 minutes.
Thanks again guys!
Old Jun 8, 2016 | 10:25 AM
cvaria's Avatar
cvaria
^this^
45-50 ft-lbs torque on those peg support bolts. don't hamfist them... don't want any shearing action on the bolts... will not end well.
MOSTWANTED
Jul 20, 2012 02:37 PM
ncbeast
Mar 21, 2011 08:53 PM
Sad King Billy
Feb 2, 2011 07:56 AM
Plasteredcat
Dec 29, 2009 06:46 AM
fatguyona1000
Jul 23, 2009 12:41 PM
