Ah me thinks a little harley 101 is in order.
What most people call a suicide shifter is in reality a jockey shift. This is a shift arm that attaches to the tranny like your shift leaver does but is run vertically to be shifted by hand . It was first used back in the days of foot clutch tank {hand} shift. The term suicide was used in reference to the foot clutch not the shifter for when the spring that kept the foot clutch in the disengaged position was removed so you had to keep your foot on the clutch when stopped . If your foot slipped off the clutch would engage causing the bike to lurtch forward. And yes I know even the guys from OCC refer to a jockey shift as a suicide shift but they are wrong!
I'm sure I have seen a hand shift with the clutch lever attached to it so you can do everything with your left hand. Can't remember what catalogue it was in though.
