Need a Fork Brace
Old Jul 5, 2016 | 08:01 PM
lh4x4's Avatar
lh4x4
The 48 has a wider spread between the forks and the factory brace is the only option. Just order a new one from parts.
I have a 14 XL1200T with the same wide spacing and the only way for me to add a brace is to buy the 48 lower sliders and add the brace. That would be $$$.
I have searched the aftermarket and there is no company that makes a fork brace for anything other than the standard width spacing. The 48 and the T are the Wide Glides of the Sportster world. I think the diameter of the sliders is a few mm more than the others also.
What I did is measure the width of each forks centerline and found that it matched the Dyna. Got a h-D Dyna fork brace and since the diameter of the Sportster is smaller I shimmed it with an aluminum bar stock of the needed thickness and wala a fork brace.
Old Jul 5, 2016 | 08:07 PM
19Sparrow87's Avatar
19Sparrow87
https://superbrace.com/collections
Found this on my searches. Maybe this will help ya out
Old Jul 5, 2016 | 08:17 PM
Dented's Avatar
Dented
I've seen this brace. It may fit the forks but it would leave the the holes that are there unused. I'm ordering the stock brace without the fender.
Old Jan 30, 2017 | 02:03 PM
boydlife's Avatar
boydlife
Stage I
Originally Posted by Dented
I just bought a used 48 and it's missing the fender/fork brace. There does not seem to be any aftermarket braces out there for this bike which is insane because I see them for everything else. I don't want to go universal because the holes are right there for it.
I think i would look silly to have leave the holes empty and put a brace over it.
Any ideas?
If still looking I have brace and fender
Old Jan 30, 2017 | 04:00 PM
Dented's Avatar
Dented
Default Fork Brace
I bought the stock brace. I didn't realize it was part of the fender.
Your picture didn't load.
Thank you for checking.
IronBoy883
Feb 6, 2011 05:09 AM
rounder
May 12, 2010 02:01 PM
Pirate Boy
Feb 20, 2010 09:23 AM
wiegs
Jun 16, 2008 09:35 PM
Broken Leg Rider
Aug 6, 2006 08:10 PM
