Oil on Cooling Fins
Old Jul 13, 2016 | 02:14 PM
DCrider132's Avatar
DCrider132
Default Oil on Cooling Fins
I've noticed over the past several weeks an oil residue gradually covering the front fins of the forward cylinder and behind the rear cylinder. Is this just blow by? Should I clean the fins periodically, maybe w/a toothbrush or something, or is it something worse?
Old Jul 13, 2016 | 02:15 PM
KCCO-Forty Eight's Avatar
KCCO-Forty Eight
Have you recently changed anything on/in the motor? Rocker covers, etc?
Old Jul 13, 2016 | 02:19 PM
cvaria's Avatar
cvaria
sounds like rocker gaskets but, no pictures or other info was provided. wash the engine up really good, check your oil level, then take it out for a long ride. see what happens.
don't worry. if it is the rocker covers... it's not major and relatively easy to fix. post some good pictures before you wash the engine.
Old Jul 13, 2016 | 05:47 PM
Ratwerke's Avatar
Ratwerke
Sounds like a recent event for me too. Yes it was the rocker gaskets, be sure to also keep an eye on nearby bolts, as they will back out due to the oil penetration. (See pic below)
Upper left engine mount, forward cylinder.
No H2O
Engine Mechanical Topics
Mar 28, 2019 09:11 AM
ripto
Jan 15, 2017 10:21 AM
adm
Feb 1, 2016 01:56 PM
StargazerXT12
Oct 24, 2007 11:13 AM
bigfish
Ironhead
15
Jul 6, 2006 01:34 PM
