Might even be a good idea to replace it, might have gotten pinched on install and is likely to do it again, maybe in a much more inconvenient location like a couple hundred miles from home.
For something that small I'd go to the dealer, unless of course they pull the old "you have to buy the whole fuel injector assembly" BS.
If Harley will only sell the complete assembly just remove one O ring and take it to an auto parts store, they normally have a box behind the counter with a hundred different sizes of O rings and can just visually match it up. Just make sure to match both the diameter and thickness of the O ring.
