Engine casings
Old Nov 21, 2016 | 01:26 AM
stevehd1200's Avatar
stevehd1200
2nd Gear
Default Engine casings
Hi all, new guy from UK here, just acquired my 5th sporty (1999 hugger 883) my trouble is that the engine casings are a little corroded, any ideas on the best way to clean them up ?
Cheers guys
Old Nov 21, 2016 | 04:37 AM
Almond farmer's Avatar
Almond farmer
Can use mag wheel cleaner , which is a phosphorus based acid.
Basic oven cleaner from grocery store will also work but is more aggressive than mag wheel cleaner.
Have also used a fiber hand drill operated abrasive wheel, which is the least aggressive.
Old Nov 21, 2016 | 11:58 AM
TStephen's Avatar
TStephen
Cheers guys
Soda blasting works great and you don't need to spend a bundle on the setup, if you already have a good compressor.
Old Nov 21, 2016 | 02:32 PM
grbrown's Avatar
grbrown
Cool
Steve, hello old chap and welcome to HDF from nearby. It's called 'patina' - wear it with pride! Some custom shops go to a lot of trouble to make a vehicle look old and well used......
Jaystn62
Oct 22, 2011 06:41 PM
cmancini26
Oct 1, 2011 10:14 AM
ezekielta
May 10, 2010 08:23 PM
biskit
May 4, 2008 10:58 AM
Road_Clam
Mar 30, 2007 12:38 AM
