Wheelweights
Old Nov 26, 2016 | 07:43 PM
cvaria's Avatar
cvaria
Originally Posted by drinktothat421
The "ride on" is like dyna beads But just liquid plus a sealer? Like the stans notubes sealer?
can be used with tubes. i used it in my dynas spokes/tubes.
http://www.ride-on.com/motorcycle-formula-mot.html
"Works in Tubes and Tubeless Tires - Ride-On TPS will eliminate 85-95% of your flats in tubeless tires from objects up to 1/4" (1/8” for tube tires) that penetrate the contact area of your tire. Due to a tire’s inner curvature, Ride-On will not seal sidewall damage, or damage near the shoulder of the tire (the outside 1-1.5” of the tire tread). If a tire has a cut, impact break, bruise, bulge, snag, or sidewall damage, take the tire out of service and have it inspected by a professional tire care specialist."
Old Nov 26, 2016 | 09:05 PM
drinktothat421's Avatar
drinktothat421
I understamd what tire sealer is i use stans notibes for my tubless moutain bike. But the sealant help blance like the "dyna" beards are suppost too
Old Nov 26, 2016 | 09:07 PM
perki48's Avatar
perki48
Ride-On does an excellent balance job.
Old Nov 27, 2016 | 04:44 AM
81rat's Avatar
81rat
" Ride On " dose both-- seals and balance at the same time . remove the valve stem install a certain amount air tire back up
If you have a tire that's out of balance and starts to cup the tread you have less contact on the payment ( not good ) and once it starts to cup it won't straighten back out . TAKE CARE OF YOUR TIRES as a favor to yourself
Old Nov 27, 2016 | 09:22 AM
cvaria's Avatar
cvaria
yes, there are no weights on my dyna wheels. the roadster wheels will also not be getting weights. the first miles with ride on are weird. once it coats the tire/tube, it smooths out.
if it freaks you out, that's okay. nothing wrong with keeping it old school and scoring some weights.
Old Nov 27, 2016 | 09:27 AM
Kenny94945's Avatar
Kenny94945
Besides a vibration free "feel" IMO the only way to verify is to check the balance on a machine.
How's a low cost Harbor Freight tool for such a test?
Good luck.
Old Nov 27, 2016 | 09:48 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I seriously doubt any wheel/tire can be in balance without wheel weights, unless a product like Dyna Beads or Ride on are used.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Nov 27, 2016 | 11:11 AM
billib1954's Avatar
billib1954
my new avons required no weights, acetone remove the black residue from the wheels where they dunlops required numerous weights.
Old Nov 27, 2016 | 12:21 PM
Sandcrab's Avatar
Sandcrab
Default Quick test
Just got new tires mounted at my dealer. I noticed i had no wheels weights. The serivce guy say they didn't need tem They were balanced....
If it is the front tire, a quick way to check is to remove the brake calipers, and see if the tire moves from different locations. If it is the rear tire, it's too much trouble.
Old Nov 28, 2016 | 03:34 PM
grbrown's Avatar
grbrown
Lightbulb
My recently installed new Avon front tyre has no wheel weights, it's also not the first new tyre that has needed none. You started this thread from the premise that you don't trust your dealer, well the proof of the pudding is in the ride, so try your bike and see if you can detect any imbalance. If you do go back to the dealer, if not head off to the horizon!
