front end wobbles when i let go of bars
Old 03-28-2017, 03:04 PM
red sport.'s Avatar
red sport.
red sport. is offline
I replaced my rear from Dunlop to Michelin Com. 2 ( Dunlop on front) & my bars would shake when slowing down with hands off or loose on grips, at H speeds it was just not smooth I put another Dunlop on problem solved
Old 03-28-2017, 05:41 PM
cHarley's Avatar
cHarley
cHarley is offline
10,000 miles is a fairly major service interval that includes doing the "Fall Away" test/adjustment, detailed in the Service Manual. This is the neck bearing "tension" adjustment.
Old 03-29-2017, 04:39 PM
artc's Avatar
artc
artc is offline
YourTire pressure is what in the front?
Old 04-08-2017, 01:00 PM
madchemist24's Avatar
madchemist24
madchemist24 is offline
Originally Posted by jSavage-1
Hey guys, new to the forum here an I have a question about my Nightster.
Alright so I have a 2010 Nightster 1200 an last year while at a little get together one of my buddy jumps on my bike who's never ridden an needless to say he no more than let the clutch out an dumped my bike in his front yard leaving a nice dent in my tank, folding my clutch lever around and bending my bars a little. Not to happy about it. Anyways when i let go of my bars now the front end starts to shake. The bike just turned 10k miles. Any ideas on what it could be? Wheel out of balance? Wheel bearings worn out? Any input would be great thanks!
sorry to hear about the dump ... sad cost of letting others on your bike.
My 07 has never been dropped. It rides smooth up towards 60 mph, however, if I loosen my grip and let the bike slow on its own, it has a vibration in the front that bounces the bars/wheel from 45 to about 30 mph then its smooth again. Holding the grips, there is no vibration. There is another vibration that shakes the bike between 70-75 and smooths again over 75. Trying to figure it out. So far everything looks good.
Anyways, about your bars ... if you are interested, I have my stock Nightster bars hanging on the garage wall collecting dust and they can be yours for shipping cost. send a PM if interested.
Old 04-08-2017, 01:12 PM
Almond farmer's Avatar
Almond farmer
Almond farmer is offline
If the front wheel is laced with spokes , the rim may have been bent resulting from the fall over.
Need to remove wheel and check radial and lateral run out and spoke nipple torque.
Spokes will loosen up even from normal use.
Old 04-08-2017, 06:16 PM
bagga's Avatar
bagga
bagga is offline
i would check for loose rear spokes. front end shake can start from the rear too.
madchemist24 (04-08-2017)
Old 04-08-2017, 07:29 PM
Almond farmer
bagga, totally agree
The 2006 Dyna frame was stiffened with added weight to compensate for dynamic imbalance, since the lateral center of gravity is not inline with the frame center line.
The heavy mufflers on the right side helped the situation. Sputhe engineering likened it to having a bar bell sitting diagonally across the bike frame.
Sputhe designed and prototyped two vibration isolators to help absorb some of the vibration.
The instability was caused by side to side motion of the rear tire contact patch from the imbalance even on a smooth as glass riding surface.
The result of the instability caused the handle bars to wobble.
Cazador
Milwaukee Eight (M8)
31
09-15-2018 01:29 PM
rubberguy
12-09-2015 06:15 PM
Johns98roadglide
06-11-2013 10:20 AM
johnny reb
General Topics/Tech Tips
11-28-2012 12:45 AM
az426hemi
01-26-2009 09:46 PM
Quick Reply: front end wobbles when i let go of bars
