Front end wobble at around 40
Old Jan 26, 2009 | 05:36 AM
az426hemi's Avatar
az426hemi
3rd Gear
Default Front end wobble at around 40
I get this wobble when I let go of the bars.
Also the bike pulls to the right.
The bike is an 89 FLHS.
Any ideas?
Mike
Old Jan 26, 2009 | 06:00 AM
ripper43's Avatar
ripper43
Jack up the bike with the front wheel off the ground, turn the bars from stop to stop and see if you feel any dragging, notching or extreme looseness any where in it. More than likely you need new steering head bearings. It could be something else but that's where I would start.
Good luck.
Old Jan 26, 2009 | 06:49 AM
skootchnc's Avatar
skootchnc
I'd start with checking air pressure first.... but steering head bearings is most likely
Old Jan 26, 2009 | 06:53 AM
strtrod's Avatar
strtrod
I had this problem before with a wideglide & it was 3 spokes loose in the rear wheel.
Old Jan 26, 2009 | 09:43 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Rear spokes would be the first thing I check also.
Old Jan 26, 2009 | 12:04 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Diy
You might also go here to my web site, hope this helps, but if it don't it is much better than a sharp stick in the eye.
Old Jan 26, 2009 | 12:35 PM
gunner11's Avatar
gunner11
Don't let go of the bars?
Old Jan 26, 2009 | 01:35 PM
curtiso504's Avatar
curtiso504
If you have laced wheels (spokes) definitely have them trued. I caught a vicious wobble when I would let off the throttle. Was rear wheel out of true. Easy fix.
Old Jan 26, 2009 | 01:57 PM
Dr.Hess's Avatar
Dr.Hess
When my 86 FLHT did that, it was neck bearings loose.
Old Jan 26, 2009 | 02:36 PM
Big Jake's Avatar
Big Jake
+1 on the loose rear spokes. I had it happen to me as well. When I rolled off the throttle the front end would shake all the way down the road. Take an allen wrench and ping the spokes. You will know quickly which ones are loose.
