Stage 1 mpg
Old Apr 4, 2017 | 08:54 AM
Bowhunter8607's Avatar
Bowhunter8607
I'm around the same fuel consumption as deadrubberboy and averaging 30 MPG riding in town. I do rip it quite a bit but not excessively. Maybe more autotuning is required to get better milage? Not sure but I know even stock I was averaging 35 MPG so not sure what's causing mine to consume more fuel than most here.
Old Apr 4, 2017 | 12:19 PM
deadrubberboy's Avatar
deadrubberboy
Ditto.
Old Apr 4, 2017 | 01:36 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
A good Stage I (and they are NOT all the same) will give you the same or a bit better MPG, IF you ride the same. A lot of times the extra power tempts one to ride more aggressively, and then there is a drop in mpg.
On my Sporty, which I ride pretty aggressively most of the time, gets around 40 mpg. The little bit that I ride a bit more sanely it will jump up to around 43-44 mpg.
This is with the Power Vision AND the Target Tune.
When I had just the Power Vision, I was down around 32-35 mpg.
It had a ton of power with the Power Vision, but when I added the Target Tune, not only did I start getting significantly better MPG, my throttle response went WAY up...much snappier acceleration.
Top WOT dyno numbers did not change...it is all the riding between cruising and WOT that was greatly improved.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 4, 2017 | 01:50 PM
deadrubberboy
Thanks for the info Kevin. I too have a Power Vision - no target tune though. It's pricey, and after ready JauntyBiships write up today on adding the Target tune with the Patriot Defender (same pipe I have) requiring him to cut away some parts to make the new 02 sensors fit, I think it's off the table for me.
Old Apr 4, 2017 | 01:58 PM
T^2's Avatar
T^2
2009 Nightster, V&H Side Shots, DK 636V Intake/Filter, Target Tune w/widebands installed...
I say my range is usually north of 40 MPG and south of 45 MPG.
Old Apr 9, 2017 | 07:27 PM
rdunnill's Avatar
rdunnill
That's what I got with my stock 2008 Nightster.
Old Apr 9, 2017 | 07:37 PM
Bluesrider.df's Avatar
Bluesrider.df
When I got my bike I was getting 45mpg doing a mix of highway and rural country roads. But then I discovered the moron who did the Stage 1 never put a tuner in, and the bike was running too lean. I installed a FuelMoto Micro EFI tuner, and now I average 40-42mpg.
johnod
EVO
Oct 15, 2014 07:45 PM
SURFOR Chop
Exhaust System Topics
Mar 27, 2013 09:14 PM
Stevenml155
Jan 25, 2007 09:37 PM
camman
Jun 3, 2006 01:52 PM
stc13
Apr 29, 2006 04:54 PM
