Newbie Help
Old May 2, 2017 | 10:38 PM
Splangeland's Avatar
Splangeland
Stage III
Default Newbie Help
Hey everybody! I just picked up a 2007 Nightster. I just ordered a set of V&H Short Shots for it and I'm wondering how necessary it is to order the Fuelpak FP3? Will I be ok riding it for a while until I can afford to buy one, or will I burn the engine up due to it being too lean? I don't usually ride for more than 1-2 hours at a time. Thanks in advance for the help!
Old May 2, 2017 | 11:20 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Old May 3, 2017 | 12:38 AM
critter85's Avatar
critter85
Welcome to the Forum from Kansas
Old May 3, 2017 | 06:28 AM
Thumper26's Avatar
Thumper26
You should be just fine with the the stock mapping. The stock map should easily adjust for the change in exhaust.
Old May 3, 2017 | 06:30 AM
attaboy15's Avatar
attaboy15
Welcome from Nor Cal
Old May 3, 2017 | 11:35 AM
Splangeland
Stage III
Thanks for the warm welcome! I was hoping to hear I would be ok, thanks again!
Old May 3, 2017 | 03:01 PM
mrhammer2u's Avatar
mrhammer2u
Come back and let us know how she runs with no tuner. Especially low speed/low rpm like putting around town. Curious to hear if you feel a difference.
Old May 3, 2017 | 09:20 PM
Splangeland
Stage III
Got them put on tonight. I can't say I notice much of a difference at all putting around town. Granted, I live in a two stoplight kind of town so I spend very little time at a low RPM/Speed. I would have to say I noticed it at higher speeds though. At 55 in 5th gear it doesn't seem to pull as hard as it did with stock pipes. I'm going to order the tuner in the next few days, it looks really cool!
Old May 5, 2017 | 08:16 AM
mrhammer2u's Avatar
mrhammer2u
With those pipes you will lose some mid range grunt because of the loss of the stock crossover pipe. I rarely use 5th below 60. Especially with straight pipes like you now have. That rpm range is exactly where you've lost power.
Old May 8, 2017 | 02:40 AM
BensonUK's Avatar
BensonUK
the way it was explained to me was
you can change the air in - no fuel changes
you can change the air out - no fuel changes
change air in and air out - fueling changes required
bullfrogsFLHTK
Welcome Area Only
18
Feb 24, 2015 08:46 AM
kochise
Welcome Area Only
19
Oct 6, 2014 09:21 AM
PutitOnme
Welcome Area Only
Mar 10, 2013 09:10 PM
Mopar5599
Welcome Area Only
18
Jun 9, 2012 08:41 AM
jackie
Welcome Area Only
Nov 30, 2007 06:12 AM
