Torque specs
Old May 30, 2017 | 04:08 PM
cbacon1788's Avatar
cbacon1788
Default Torque specs
I have a 2002 Sportster 883 and was wondering if anyone could give me the torque spec on this big bolt in the center pictured here? Thanks in advance!
Old May 30, 2017 | 04:10 PM
cbacon1788's Avatar
cbacon1788
Also wondering what socket size that is
Old May 30, 2017 | 05:19 PM
Scuba10jdl's Avatar
Scuba10jdl
There isn't one. That's your stem nut and you tighten it however much is needed to set the proper fallaway of the front end and neck bearings.
Old May 30, 2017 | 05:41 PM
Ratwerke's Avatar
Ratwerke
It's one thing to change oil, but you really should obtain a factory service manual when performing work of a nature that could affect your safety. Not trying to be 'that guy', but just some friendly advice
Old May 30, 2017 | 05:43 PM
cbacon1788's Avatar
cbacon1788
no worries very much appreciated especially safety tips... will have to look for a manual to pickup and check it out
Old May 30, 2017 | 05:48 PM
HOTLAP's Avatar
HOTLAP
Make sure to get a proper Harley service manual for your model/year, the off brand manuals are crap compared to the Harley one.
Old May 30, 2017 | 08:29 PM
Bluesrider.df's Avatar
Bluesrider.df
If that stem nut is too loose. front end will wobble on deceleration. If too tight, you could damage the head bearings. Agree with the others, get the HD factory service manual, accept no substitutes.
Old May 31, 2017 | 04:33 AM
shanneba's Avatar
shanneba
Here is a link to the part numbers for the currently available Harley service manuals-
https://shop.newcastlehd.com/sites/d...literature.pdf
Old May 31, 2017 | 05:49 AM
grbrown's Avatar
grbrown
Wink
You can get them at your local dealer, or from on-line dealers. Beware the ones you see advertised on Ebay as the prices are inflated, even for secondhand ones, and higher than you'll pay locally for a new one.
Old May 31, 2017 | 03:47 PM
cbacon1788's Avatar
cbacon1788
Anyone happen to have the info on tightening this down so I can do it in the meantime while getting a manual
