Oil problem
Old Jun 25, 2017 | 09:42 AM
tim selock's Avatar
tim selock
Stage IV
Default Oil problem
Why is my reservoir filling up?
Old Jun 25, 2017 | 09:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Could you be a little more vague?
Old Jun 25, 2017 | 10:43 AM
Ratwerke's Avatar
Ratwerke
Gonna have to assume too much oil, with the limited info.
Did you put 3qts in, instead of 2 and check levels?
Old Jun 25, 2017 | 12:06 PM
John Harper's Avatar
John Harper
Because your bike sat and oil drains down into the crankcase.
John
Old Jun 26, 2017 | 06:41 AM
tim selock's Avatar
tim selock
Stage IV
It's a 94 sporty I had to clean my carb and mess with the tuning I had the oil at the right level and I ran out of time to get it running. I checked the oil level and it was to the top of the resevior. Where is it coming from? Why is it filling up?
Old Jun 26, 2017 | 06:55 AM
hexnut's Avatar
hexnut
Did you fill it with out starting it to get the oil that had drained down in the crank case pumped back in the oil tank. If you did when you got the level right and started it the oil in the crank case was pumped back into the oil tank causing it to be over filled.
Old Jun 26, 2017 | 07:32 AM
tim selock's Avatar
tim selock
Stage IV
I didn't touch the oil. Is this a normal or somewhat normal thing? I need to do an oil change should I just do that?
Old Jun 26, 2017 | 08:23 AM
grbrown's Avatar
grbrown
Wink
Tim, it is likely that some oil had drained from your oil tank into the engine, so that when you next ran the engine that 'extra' oil came back into the tank. Oil will do that if your bike stands for any length of time. In future run your bike for a few minutes before you check the oil level. Only then should you top it up, or indeed empty the tank to do an oil change. If you don't have one get yourself a factory service manual, which will give you guidance on all servicing matters. Your local friendly dealer can supply.
Old Jul 4, 2017 | 10:53 AM
tim selock's Avatar
tim selock
Stage IV
Default Why would my oil cap shoot off?
What's causing the pressure? Bad pump?
Old Jul 4, 2017 | 11:35 AM
cHarley's Avatar
cHarley
Only working with the very limited info you provided, too much oil, as said above.
