Finding TDC using a soda straw
Old Jun 29, 2017 | 05:23 PM
lewk's Avatar
lewk
Default Finding TDC using a soda straw
Hi all,
I watched some youtube clips and a couple of them mentioned finding TDC using a drinking straw but they never really demonstrated it or explained it clearly.
So here is what I think:
  1. Strap bike down, level it, jack up rear wheel
  2. Remove spark plug
  3. Insert clean dry straw in spark plug hole
  4. Turn rear wheel slowly
  5. When straw is most exposed above hole, that's TDC for that piston
Is that correct?
Old Jun 29, 2017 | 05:31 PM
lightweight bob's Avatar
lightweight bob
The trouble is that it will be at TDC for some time - not just an up and down action.
Mark the straw about an inch before it reaches TDC, continue rotating on past TDC
until the straw goes back down to your mark on the straw. Half way between those
two points will be TDC.
Old Jun 29, 2017 | 05:35 PM
lewk's Avatar
lewk
Ok, so make a marker pen mark on the straw and when the mark starts coming back down, I should go back by reversing the wheel. Right?
Old Jun 29, 2017 | 05:42 PM
hexnut's Avatar
hexnut
deleted
Old Jun 29, 2017 | 05:48 PM
lewk's Avatar
lewk
Originally Posted by hexnut
You need tdc on the compression stroke were both valves are closed.
Ermmm... English please? Total newb here
You have to be looking at the rocker arms to determine this.
That one too, please explain? What will the rocker arms be doing, to indicate it's TDC?
And the bike needs to be in 5th gear when turning the wheel to rotate the engine.
Now that I understood!
On a 4 stroke engine there are two TDCs
Do you mean one for each piston?
Old Jun 29, 2017 | 06:03 PM
hexnut's Avatar
hexnut
deleted
Old Jun 29, 2017 | 06:09 PM
lewk's Avatar
lewk
... Rotate the motor forward and watch what's happening on the intake side ...
Which rocker arms are the intake side? The ones closest to the air cleaner inlet?
Old Jun 29, 2017 | 06:18 PM
hexnut's Avatar
hexnut
deleted
Old Jun 29, 2017 | 06:40 PM
lightweight bob
Default Tdc ???
Keep going in the same direction. As a matter of fact, if you mark the straw about 2 inches before it tops out and continue to rotate
the engine until it falls back down to the mark the TDC measurement will be more accurate. This is because at half stroke rod angularity
is the highest along with associated piston speed per degree of crankshaft rotation.
On a four cycle/stroke engine TDC happens on the compression / firing power cycles and again on the exhaust / intake cycles. On V-twin
engines TDC is at an entirely different crankshaft rotation place for each cylinder.
Determining if you're on a compression or exhaust stroke can easily be done by just putting your finger over the spark plug hole while
rotating the engine - you'll only feel pressure on the power stroke.
Old Jun 29, 2017 | 09:19 PM
JustOneDean's Avatar
JustOneDean
These are four-stroke engines, meaning a complete combustion cycle takes four strokes of the piston in the cylinder. The four strokes are intake (intake valve opens, piston goes down to suck in fresh air and fuel), compression (both valves are closed, piston goes up to squeeze the air-fuel mixture), combustion (spark plug fires, burning the compressed air-fuel mixture and driving the piston down), and exhaust (exhaust valve opens, piston moves up to force the spent air and fuel out of the cylinder to make room for a fresh mixture at the start of the next combustion cycle).
So in a single given cylinder (our bikes have two), you have two upstrokes and two downstrokes. You want the piston to be at top dead center of the compression stroke (the first upstroke) because that means both valves are closed, so there's no more pressure on the valvetrain than there has to be. If the piston is at top dead center of the exhaust stroke (known as "overlap"), the exhaust valve still hasn't closed and the intake valve has already opened. There's a lot of pressure on the valvetrain, which can cause damage when you start unbolting things.
The way most of us know the four strokes is "suck, squeeze, bang, blow."
