clutch help
i made a clutch adjustment through derby cover and adjusted clutch cable per the service manual, though i changed one step— i first slackened the clutch lever by loosening the jam nut and then turning the adjuster on the cable, then i went in through the cover and adjusted the adjusting screw and re-installed the hex lockplate. the service manual recommends the opposite. i did this per advice from a youtuber mechanic that i trust. i'm not sure that this makes any difference. note: the outer ramp upon which the adjusting screw inserts seemed really loose. it took at least a half turn, maybe more, before it seated. i then went out the prescribed 1/4 turn and replaced derby cover. clutch seemed fine for a while, then all my problems returned (all but the knocking of gears in 1st. odd . . . ).
after more troubles, i tried adjusting the clutch cable. this seemed to work for a day or two, then more troubles. repeated entire clutch adjustment, cable and adjusting screw through derby cover. all seemed fine for a day or two, then more troubles. i have been making periodic cable adjustments and that seems to fix it for a while, but then it goes out again.
if i take it in, i'm afraid that harley will charge me for a simple clutch adjustment, which seems to work for a while etc. also, i read somewhere that the transmission level can wreak havoc on the operation, even disable it. my transmission level is correct.
may not be the plate at all but, it's possible with that mileage if it was never removed and it is the stock clutch pack.
others will chime in
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://www.youtube.com/watch?v=zQnlt8twX3k
there's also a thread here with a few having made and used a DIY tool.
clutch packs
energy one
or
barnett
https://www.amazon.com/Barnett-Extra...utch+sportster
write up (needs to be updated... pictures are all MIA): https://www.hdforums.com/forum/sport...t-writeup.html
some pictures: https://www.hdforums.com/forum/sport...l#post16063264
