What else to remove?
I commuted daily in Socal traffic with a jockey shift and floot clutch on the same Sporty because I wanted to clean up my bars and get rid of a clutch lever. It was cool but it kept breaking the cable so I ended up switching back eventually. I still miss my clean bars.
Last week I removed the front fender, and the belt guard (upper and lower), then put on an Arlen Ness stage 1 big sucker air intake. Today I did a tank lift (1.5") and removed the plastic wire covers and did a wire tuck (my first time, looks ok). Then I removed the horn and mount.
I plan on ordering a LAF Ground Shaker exhaust to replace the stock exhaust.
Next year I will put a S&S Hooligan 883cc to 1200cc plus cams upgrade kit in.
What else should I do? Need suggestions. Looking to remove unnecessary crap to make this skinny girl lighter.
Oh, I'm new to Harley's and the forum (1st thread, 3rd post).
Wiz 🤣
the first few pages), you're looking to remove 'stuff' to make
the bike lighter ?
IMHO, there's not a whole lot you can do(quickly/easily).
Chop the rear fender, cut the struts down, and consider a
Lithium battery (much smaller size & loose ~7-8lbs) are
about the easiest things to do fairly quickly.
Do a 1200-1275cc upgrade, the performance increase you
get from that may change your mind as for the need to 'remove stuff'.
good luck,
T.
