Bonehead idiot needs help
Old Aug 12, 2017 | 01:27 AM
Dheez's Avatar
Dheez
Default Bonehead idiot needs help
Hi I am the bonehead idiot with a 2015 sporty.
My neighbor and I wanted to go for a ride and I had left my key in the ignition so the battery was dead.
My neighbor told me I could jump my battery with my car as long as my car isn't running. It was dark out and I am dumb so we accidentally connected the positive end to my sportys negative side of battery.
I realized how dumb I was after about 10 seconds and switched the wires out.
Now I get a grinding/clicking noise when I try to start the bike and nothing else. Doesn't sound like its trying to turn over, just grinding noises.
We've already established that I am an idiot, does anyone have any idea as to what I may have possibly fried?
Thanks very much, any help appreciated for the moron.
Old Aug 12, 2017 | 02:11 AM
03fattyaz's Avatar
03fattyaz
Check the fuses.
Old Aug 12, 2017 | 05:44 AM
Fightinggoat's Avatar
Fightinggoat
If it's clicking but not turning over, it's not a fuse, sounds like the battery is too discharged or weak to me.
Try to jump it off again (with wires is proper location) or replace the battery. Either way get current battery tested after getting it to run, it may just be time for a new one.
Old Aug 12, 2017 | 06:29 AM
Hoginedgewood's Avatar
Hoginedgewood
Fix the known problem first, charge the battery, I would do it slowly. Jumping only puts the strain on the bike. You gave the bike enough stress already. If the battery takes a charge, then you could try starting, or load test the battery.
Probably no permanent damage.
Old Aug 12, 2017 | 06:33 AM
Dheez's Avatar
Dheez
Originally Posted by 03fattyaz
Check the fuses.
All 3 fuses on the main box are good.
Thanks
Old Aug 12, 2017 | 06:34 AM
Dheez's Avatar
Dheez
Thanks, I will try and grab a new battery tomorrow.
Old Aug 12, 2017 | 06:36 AM
Dheez's Avatar
Dheez
If I cant find a new battery tomorrow locally, is there a certain battery charger that you would suggest?
Thanks
Old Aug 12, 2017 | 06:47 AM
mskirwin's Avatar
mskirwin
Any auto parts store will carry the battery. The best bet is to buy a trickle charger that you can use over the winter of its sitting for awhile like a battery tender brand. If it's not the battery you might have fried the starter seloniod.
Good luck
Old Aug 12, 2017 | 07:30 AM
RANGER73's Avatar
RANGER73
If any thing you destroyed your battery, replace it.
Old Aug 12, 2017 | 07:53 AM
Imold's Avatar
Imold
Thanks
I have two of these, but older models, don't do lithium. They've successfully charged a couple batteries my Battery Tender brand gave up on, motorcycle and auto. My van sat unused long enough a couple years ago the battery went dead, and even a conventional auto charger wouldn't charge it, but this Noco brought it back, worked fine since. A badly discharged battery can take two or three charges to fully come back with one of these "smart" chargers, couldn't tell you why, but that's something the old style standard tenders won't do. I'll never buy an old style plain tender again. There are other brands, too.
Amazon Amazon
