removing engine casings
Old Jun 11, 2007 | 04:28 PM
jay71's Avatar
jay71
Stage III
Default removing engine casings
hi all
new to the forums and new to harleys, just picked up a 2003 1200c with only 400 mls on the clock. the previous owner had neglected the bike and quite a bit of chrome is lifting off the engine cases.i have managed to source some more and im getting them powder coated,but would like to know if its quite straight forward to take the cases off and put new ones on,is there anything to look out for?
any help much appreciated.
cheers
jay
Old Jun 11, 2007 | 05:13 PM
drum412's Avatar
drum412
Default RE: removing engine casings
Not much to it. Just make sure you unbolt everything that needs to be unbolted before yanking them off. After the gasket seal is broken free, the cases should slide right off, if not, you probly forgot to unbolt something. I always see poeple who try to pull the cam side case off without removing the timing cover to unbolt it from the cam shaft.
Old Jun 13, 2007 | 03:22 AM
jay71's Avatar
jay71
Stage III
cheers fella,as soon as i get the cases back i will get stuck in.
cheers
jay
Big Money
Engine Mechanical Topics
Mar 26, 2021 09:12 PM
dscottguitars
Mar 3, 2018 11:09 AM
bigdog1949
Exhaust System Topics
May 18, 2013 02:43 PM
2006FLST
EVO
Jun 18, 2011 10:46 PM
onefargorider
Jul 12, 2009 02:55 PM
