Top End Ticking
Top End Ticking
Howdy Crew,
I've been doing some internet sleuthing, but haven't quite found the answer I'm looking for.
Here's the deal:
For anyone that hasn't followed my 1250 install on my '04 883, I've been getting some top end ticking. Everything else about the bike is running great BUT at any RPM, load or not, the top end is ticking like crazy. Sounds like someone going ape on a typewriter. Even after I installed Rockouts, the noise is still there.
Any thoughts on this? Is it possible the lifters or push rods are bad?
Thanks for your help!
Here's the deal:
Sounds like valve clearance is too big. Maybe your new gaskets are thicker and the lifters can't take up the slack. Just a guess. Maybe somebody at Hammer can give you some info. I used the thin metal crush gaskets that came with the kit and had no problem. Or maybe your lifters aren't pumping up for some reason.
Dudepants (09-19-2017)
Received 2,189 Likes
Howdy Crew,
Here's the deal:
Here's the deal:
ask hammer directly. i'm sure they've seen nearly every combination of ticking.
On my bike, the ticking is on the clutch lever side, so I've ruled out lifters or pushrods and am still puzzled as to what may be causing the ticking. Like you, I too installed rockouts.
Hey Lewk, I'll have to hone in on where it's coming from tonight, I "thought" I was hearing it more from the right side.
