check engine light?
Old Nov 5, 2017 | 12:21 AM
patato-patato's Avatar
patato-patato
Default check engine light?
Since iv'e owned my 05 1200xlc the starter seems like it really struggles. It scares me at times, but it always starts. The battery seems to be good , when i plug my "battery- tender" in the amber light turns green within just a few seconds. At times it spins right up and starts and other times it struggles . The times that it struggles the "check engine" light almost always comes on. It almost seems like a starter motor issue to me dun-no (?)
Has anybody else had this problem and is there a cure? Thanks in advance for any help..........
Old Nov 5, 2017 | 06:00 AM
apache snow's Avatar
apache snow
What code does it show.
Old Nov 5, 2017 | 06:12 AM
Iceman24's Avatar
Iceman24
When you say "battery seems to be good" did you ever test it with a meter to see if it's good? How old is the battery?
Old Nov 5, 2017 | 08:20 AM
grbrown's Avatar
grbrown
Wink
A good place to start is to check that your main battery cables are clean and tight, at BOTH ends of both of them, not just at the battery.
Old Nov 5, 2017 | 12:07 PM
patato-patato
No code shows.
just check engine symbol
Old Nov 5, 2017 | 12:11 PM
patato-patato
Can i just test at the battery tender pigtail?
if so what voltage reading should i get?
Old Nov 6, 2017 | 09:15 AM
cHarley's Avatar
cHarley
Take the battery out of the bike.
Fully charge the battery.
Take the battery to an auto parts store and ask to have it "Load Tested". Almost all auto parts stores will do it for free.
Old Nov 6, 2017 | 12:41 PM
patato-patato
Thanks.... that sounds like a good solution. If the battery turns out to be ok.....then it sounds like a new starter is in my future
Old Nov 6, 2017 | 01:16 PM
Hoginedgewood's Avatar
Hoginedgewood
Starters can get new brushes, the armature can be cleaned up. Time vs money.
Old Nov 6, 2017 | 01:26 PM
sailmotion's Avatar
sailmotion
Do you routinely start in neutral? On my Ultra if I start in gear, even with the clutch fully "disengaged", there is a slight lurch and mild "strain" on the starter. Is it possible this is what you're experiencing?
