cruise control
Old Jun 18, 2007 | 11:20 AM
SportyPig's Avatar
SportyPig
Default RE: cruise control
I just did a look see at the 07's onthe HD website. The friction wheel is there. It's the black plastic star looking wheel that is just where your thumb would be when your hand is on the throttle.
Old Jun 18, 2007 | 11:28 AM
OldFenderGuy's Avatar
OldFenderGuy
ORIGINAL: SportyPig
I have seen some dealers that actually remove the star wheel before a bike is delivered (the wheel just 'screws' into an opening in the bottom on the housing)...
Guess they are worried about beginning riders using them and getting into trouble or something.
Old Jun 18, 2007 | 01:07 PM
WVHogRider's Avatar
WVHogRider
ORIGINAL: OldFenderGuy
Or they take it off on purpose so you can pay $5, $10, or$15, ($25 for a chrome one probably)for a new one once you realize that it is missing, and they tell you that it must have fallen off.
(No, I don't know anyone this has actually happened to.) It was showed to me by the salesman when I picked mine up during the walk through of the bike.
Old Jun 18, 2007 | 02:08 PM
outdoorgirl57's Avatar
outdoorgirl57
I use the 'friction star wheel' all the time, and have it set where there is enough friction to hold the throttle in it's set position when your remove your hand, but loose enough that you can still operate the throttle manually.
I wish the dealer would have given me that explanation!
If you set it and just leave it with the appropriate amount of friction, is there anything internally that will wear after awhile with rolling the throttle on and off constantly??? I'm thinking setting it that way would also help my touchy throttle problem as well.
Old Jun 18, 2007 | 02:15 PM
OldFenderGuy
ORIGINAL: outdoorgirl57
I have all my bikes set that way, and they have seen many, many miles...
All it does is to put a little 'friction' on the housing so the throttle return spring won't 'snap' the throttle closed when you remove your hand.
Leaving the friction 'lock' set that way won't hurt anything, and it's also helping when warming up your bike. Instead of overuse of the choke (on carb'd bikes), just fire up your bike, open the throttle a bit, and let it warm up on it's own in 'fast idle mode'.
thatguy021
Jul 16, 2019 05:00 PM
TroutBum
Dec 16, 2017 06:40 PM
1NewHDGuy
Jun 16, 2014 06:46 PM
Thatguy08
Apr 12, 2009 03:47 PM
plane
Aug 12, 2008 10:08 AM
