Need opioions
sporty need to spin up higher in the rpm band to work well,,short shifting on a stock motor will not make anything any better. PM me if you feel the need, my 93 has 104 hp and 106 tq AND 94,000 miles on it, that I put on it. like i said, if you want more info PM me and we can discuss it further. take your advise from people that ride and like sportsters.
marco
marco
For the 2-1's the older vance and hines pro-pipe hs, the super trap, and thunderheader are all very nice. the V&H and supertrapp are tuneable too. that would be the first step.
next would be to get a Mikuni 42 carb. both of these uprgrades are kept and become invaluable to when you step up your cams and comp and headwork, if you get them first, you will enjoy all of the benifits right from the get go and after you do further upgrades.
marco
Also keep onto your belt - chains are just so last century! They are also quieter, smoother running and near zero maintenance. Not going to a chain will give you some useful funds to buy that new exhaust!
First... There is a difference between need and want...
Do you really "need" more than what a 1200 Sporty can deliver on american roads? I'd be skeptical of an affirmative answer. What are your buddies/club members all riding? Sport bikes? This a bunch of aggressive riders? In my book, there is only so much room for play that's reasonable for public roads. Beyond that one should avail themselves of track days. I've dumped so called riding buddies in the past because they tended to get stupid. In my experience it's a common outcome of "groups" for various reasons. This is one of the reasons that I generally prefer to ride alone.
As already mentioned... You need to get rid of the drag pipes. You are likely taking a sizable performance hit in the area of the performance band that you ride in the most (low to mid range). You might consider starting with getting a good stage 1 done (appropriate set of pipes, air cleaner, and tuning/jetting). You might be surprised with the difference from just a correctly done stage 1. If not satisfied, you'd still need to components bought for the stage 1 for going further. Don't skimp on the tuning - get it done on a dyno by a competent pro.
Lastly, no matter how much money you dump into a stage II, III or IV, you are still going to be riding a Harley. Any reasonably sized, modern, stock, sport bike will wax the floor with your hopped up Sporty. So keep that in mind while you contemplate your "needs".
Oh... and as to chains vs. belts... Don't see a need for chains... Also, doing chain maintenance all the time gets to be a drag. Belts are so much better just for this alone.
marco
