Melted Battery Terminal
Old Jan 5, 2022 | 02:49 PM
Wicklow Kelly's Avatar
Wicklow Kelly
Stage IV
I think I have the answer. Aside from any wiring problems. What will melt the Negative Terminal. When someone replaces a battery, or disconnects a good one, and loses the original battery bolts, or washers. If the spacers, bolts, or washers get lost you may be tempted to ... Make your own from a box of stuff. If one of the spacers or washers or nuts or bolts are made from a non conductive friendly material like stainless steel, or anything non magnetic, execpt copper or bronze, You will get resistance to the terminal connection, which will heat-up and melt the terminal. One electricly risistant hard AF stainless washer in the stack, and the amps only go through the bolt, and will melt the terminal.
Old Jan 6, 2022 | 05:47 AM
Midpegs's Avatar
Midpegs
Buy a Motobatt . They use brass terminals instead of lead .
Old Jan 6, 2022 | 11:14 AM
Wicklow Kelly
Stage IV
Default Melted Battery Terminal
I don't need a reference to a sales company. I was just pointing out that the problem is, heat resistence in the fasteners and spacers. A stainless steel spacer will cause the terminal to heat up like a lightbulb and melt the teminal. The spacers and washers and stuff are always getting dropped and bounced away. So if you cant find it, and use the wrong type of metal .. It will melt the negative terminalon the battery. The return amperage has to force past the resistance, it heats up.
carider48
Jan 22, 2022 12:33 AM
Jessica Sinclair
May 9, 2019 12:37 AM
BSilver
General Topics/Tech Tips
Jul 14, 2017 07:27 AM
kchndo
Feb 10, 2011 09:25 AM
HDF Tech
Electrical/Lighting/Alarm
Jun 25, 2005 01:26 AM
