ADJ. pushrods
Old Mar 3, 2018 | 08:06 PM
Eddy883c's Avatar
Eddy883c
Default ADJ. pushrods
So is ADJ. pushrods worth it or will I not see the difference on my 2004 XL883C
Old Mar 3, 2018 | 08:29 PM
apache snow's Avatar
apache snow
What difference are you looking to see.
What Hammer Performance says.
Many shops will advise you at that point to change to adjustable pushrods. Not only will they ask you to fork over $100 for a set of adjustable pushrods, but they'll also inform you that you need a set of collapsible pushrod tubes to be able to make the adjustments, to the tune of another $150.
That's not only expensive, but it's also not a good thing to be doing, for a couple of reasons. Number one, an adjustable pushrod is by it's very design weaker at a given weight level than a fixed length pushrod. Number two, using collapsible pushrod covers creates more opportunities for leaks. Nevermind the hassle of adjusting them, or the possibility of one coming loose.
If you're using standard hydraulic lifters, you're far better off to simply buy a set of fixed length pushrods that are shorter than stock when using milled heads. They'll be stronger, less expensive, won't require adjustments, and won't create new risks. Hammer Performance offers some of the best pushrods on the market.
Really, the only case where adjustable pushrods make sense is when a travel limited lifter is being used, i.e. a solid or a Hydrosolid or stock lifters with travel limiting washers. These lifter designs require a precise setting of the pushrod length that can only be achieved with an adjustable. If you're using standard hydraulic lifters, save your money for things that matter.
Old Mar 3, 2018 | 08:53 PM
Eddy883c's Avatar
Eddy883c
am looking to get more performance out of my valvetrain because I have no interest in a 1250 or 1275 , I like having 883cc so am only looking to gain a small amount of performance
Old Mar 3, 2018 | 08:56 PM
cvaria's Avatar
cvaria
if you are molesting your bike often yes. if you aren't doing anything silly or don't plan on goofing around.no. i'm running them cause i'm stupid and don't give a .... and will probably swap out cams and other nonsensical stuff out of boredom. adjustbles make it easy to change things.
they will not improve your bike's performance.
Old Mar 3, 2018 | 08:57 PM
apache snow
There is no performance to be gained going to adj push rods over a solid pushrod. They both open the valves and as stated the solids will be stronger with less problems. My bike is 110 HP and it has solid push rods in it.
Old Mar 3, 2018 | 09:05 PM
Eddy883c's Avatar
Eddy883c
apache snow I have a question for you,
what's your opinion on tuning and dyno run's
Old Mar 3, 2018 | 09:14 PM
apache snow
Well if you can find a good dyno guy its about as good as it gets, but finding that guy is some times difficult. Ask cavria. I believe he had some bad experience with a dyna shop.
Old Mar 3, 2018 | 09:17 PM
Eddy883c's Avatar
Eddy883c
cavaria am told you have seen bad dyno runs any advice
Old Mar 3, 2018 | 09:53 PM
hscic's Avatar
hscic
OP - May i ask you what performance upgrades have you done to your bike....stage 1?...or is your bike stock?
Old Mar 3, 2018 | 10:03 PM
cvaria's Avatar
cvaria
Originally Posted by Eddy883c
cvaria am told you have seen bad dyno runs any advice
i let the dealer do my dynos. and they weren't great. dealer redid them after me complaining. i was going have them re-dynod by a pro then decided not to, no real ROI. there's probably 10 more hp in the sporty and 5hp/5tq more in the other bike. is that worth $1500+ and a few days out of my life? not to me.
review these rthe results of various 883s here.
https://www.hdforums.com/forum/sport...ults-here.html
you will not get massive results. you will get a better/smoother running bike with a slight bump over stock. $400+ for that dyno vs ~$400 for a good tuner and a options later down the line.
not something to rush into. maybe take sometime and soak in the info here on the forums.
