1979 Harley Davidson XLCH 1000
Old Mar 24, 2018 | 11:50 PM
WildBill79's Avatar
WildBill79
3rd Gear
Default 1979 Harley Davidson XLCH 1000
Having an issue with a rattling sort of unwinding kind of noise when I'm slowing down and the rpm'so decreasing. The noise happens with or without the clutch pulled. When this first started happening, it was short and less pronounced, now it's a bit longer and more pronounced. This doesn't happen every time I decelerate, but does happen more often now. Can someone please give me an idea of what I may be hearing..? Any help will be much appreciated.
Thanks
Old Mar 25, 2018 | 05:27 AM
81rat's Avatar
81rat
A noise at deceleration is usually in the drive train --Check the chain and sprocket for wear and tightness, drive sprocket and even wheel bearings
Old Mar 25, 2018 | 08:33 AM
WildBill79's Avatar
WildBill79
3rd Gear
It seems to be coming from the engine somewhere, or from the primary. I can't quite isolate it because it never happens at idle, only when in gear. Going to check the primary chain tension today.
Old Mar 25, 2018 | 09:33 AM
Scuba10jdl's Avatar
Scuba10jdl
I agree with you to check the primary chain tension. On decel, the top run gets slack (like with the drive train) and if too loose it can hit the case/cover. Also check the bottom of the oil tank to see if the drive chain is hitting it as well (I'm assuming you still have the CH lunchbox oil tank). If too slack they can whip it and make some marks.
1harleyman
Apr 2, 2017 08:30 PM
SouthernWalker
Aug 7, 2016 12:28 PM
46u
63
Sep 8, 2015 05:10 PM
HDF Tech
Jul 15, 2014 07:34 PM
Captain Itch
Dec 15, 2009 07:45 PM
