Running too lean
Old Apr 10, 2018 | 07:10 PM
paco12's Avatar
paco12
Default Running too lean
stock evo 1200 except drag pipes,started could only run with choke out and was too rich,rebuilt carb,went from 40 slow jet to 45,from 170 main to 180 but now runs with choke in but plugs are white,lean! Also installed. Easy adjust a/f screw
Old Apr 11, 2018 | 07:26 AM
Thumper26's Avatar
Thumper26
Personally, I would ditch the drag pies and get something on there that will give some back pressure. Drag pipes, aside from being loud, only benefit high-end speeds. Low and mid range running suffer and excessive heat can cause you problems with the exhaust valves. If you're bent on keeping the drag pipes, move up to at least a #48 and #85 jet.
Old Apr 11, 2018 | 08:29 AM
DB429SCJ's Avatar
DB429SCJ
Interesting video on exhaust. https://www.sscycle.com/tech-info/te...d-fuel-systems
Old Apr 11, 2018 | 09:07 AM
craigthecarpenter's Avatar
craigthecarpenter
If you had the carb off and didn't use brand new seals when re-installing I would check for intake leaks.
If you don't already have one of these
Yost Yost
intake manifold wrenches then I would get one.
I can remove and replace my intake manifold with the tank on using one of these. The only part other than the carb that was in the way was the VOES. EZ PZ.
Craig
Old Apr 11, 2018 | 09:21 AM
Scuba10jdl's Avatar
Scuba10jdl
Modern gas doesn't really color plugs. The insulator SHOULD be white or light tan. You can adjust the insulator color a bit by running a colder spark plug. What you don't want to see is bubbles or a glazed appearance on the insulator, as that is overheating.
45/180 and about 2.5-3 turns on the mixture screw is perfect for a 1200 Sporty. If it's in fact running lean you have an intake leak somewhere or fuel is not being delivered properly.
Old Apr 11, 2018 | 10:10 AM
Studly Doright's Avatar
Studly Doright
Stage III
i just bought the dynojet kit for my 2006 1200 sporty. with after market exhaust and airbox it recommends 175 main and 3.5 turns on the mixture screw.
Old Apr 11, 2018 | 11:05 AM
Scuba10jdl's Avatar
Scuba10jdl
Dynojet main jets are sized completely different...
OneHarleyAtATime
Carburetor Related
Jun 11, 2017 05:09 PM
jfuller9
Jul 28, 2013 09:26 AM
Cygnus x-1
Exhaust System Topics
Sep 3, 2011 08:01 PM
JBaker421
EVO
13
Mar 13, 2008 01:57 AM
jackofhearts
Mar 1, 2008 05:24 PM
