Breather venting
Old Apr 17, 2018 | 03:46 PM
  #31
firehawk6's Avatar
firehawk6
Originally Posted by T^2
To each their own...
I agree, while that style of air cleaner isn't my cup of tea either, it's totally up to the owner, it's his/her bike.
I consider the oval shaped air cleaner kind of an iconic part of the Sportster and that's why I wanted to stay with it.
Old Apr 17, 2018 | 05:04 PM
  #32
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by lewk
Does it makes a significant improvement over a filtered v-stack? I'm just curious.
Yes, in the 10-15% range, and in the 5-10% range over a good round or oval set-up.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 17, 2018 | 05:06 PM
  #33
lewk's Avatar
lewk
Whoa... I had assumed that a v-stack would perform better than a good round/oval setup.
Old Apr 17, 2018 | 05:27 PM
  #34
DK Custom's Avatar
DK Custom
Platinum Sponsor
No. There is a lot more to extracting power from an air cleaner than what meets the eye.
Very important is HOW the air is organized...how it flows, once it is past the filtering element.
The V-Stack will flow better than many round or oval set-ups, and MUCH better than stock, even better than the stock box with a K&N filter element, but not as well as the 425, 587 or 606...nor as well as some other good aftermarket A/C's.
MOST engines will produce more power with a free flowing air cleaner on them than if there is nothing...just the open throttle body or carb.
The 636v has a particular advantage because of the patented shape of the intake tube which produces a Venturi Effect, increasing the Velocity of the air entering the carb/throttle body.
When we first tested the 636v, ourselves AND the dyno operator thought something must be wrong with the dyno....we did quite a few retests, along with testing other forward facing A/C's.
Below is a comparison of the best runs of each of 4 different forward facing A/C's.
You may also find this REPORT an interesting read.
pugmommie
May 20, 2019 01:14 PM
tunafisher729
Jan 11, 2019 01:37 PM
Ramblin_Gunner
Jul 26, 2012 12:13 PM
3itodd
Jul 12, 2011 07:34 AM
SoCal Harley
Jul 26, 2005 12:47 PM
