2016 Roadster CX - NO KEY - Turn Signal Lights ON
Old Apr 23, 2018 | 08:06 AM
kingkupal1's Avatar
kingkupal1
Default 2016 Roadster CX - NO KEY - Turn Signal Lights ON
If anyone can help me with this.
BACKGROUND: I added a rear MoonsMC tail light to my integrated rear turn signals. It's a plug and play. Bought the split harness from HD. Plugged it into the existing stock harness jack and all works fine.
I have a good 200 miles on this light. The other day, when I turned off my Harley, removed keys, the front and rear turn lights stays on (NOT the MoonsMC). My SEA for the tender does not work either.
I unplugged the harness and re-plugged it, lights goes off. Problem, my SE plug fuse was burnt. I replaced it, it worked fine.
I rode for a 100 miles and It happened again. Anyone has an idea of the problem here?
Old Apr 23, 2018 | 08:38 AM
cvaria's Avatar
cvaria
Did you seing by the dealer and have them tell your bike that there is a 3rd light with the digital technician?
may not be the cause but, cant hurt. My sporty isn't canbus so the situation is different there. I had funky issues with my canbus dyna because the dealer told the bike it was a lowrider.. bike did all sorts of weird **** because it is a wide glide with only two rear light that are RTB not separate turns and brake lights. Long story on the drama but, they figured it out after i complained. Reset it to default wide glide settings... all good after that. Free.99
Old Apr 23, 2018 | 08:53 AM
kingkupal1's Avatar
kingkupal1
Thanks. That is what I am going to do now.
Old Apr 23, 2018 | 03:05 PM
kingkupal1's Avatar
kingkupal1
$120 for the dealer to do it. I love New York.
79289Chase
Electrical/Lighting/Alarm
May 14, 2018 02:06 PM
WDOMAKR
Feb 19, 2014 07:35 PM
fatboy1729
Mar 23, 2012 12:08 PM
Filmy
Mar 31, 2009 10:49 AM
lrntowrench
Aug 15, 2008 06:49 PM
