starting issue
Old May 11, 2018 | 05:31 PM
jpkremers's Avatar
jpkremers
Stage II
Default starting issue
Hello,
I have a 1999 Sportster 883. After leaving it sit for several weeks (ran fine) when I turn the key on there is no lights, start, turn signals, etc. I tried a battery out of another bike that runs fine and no go. I also, at the recommendation of the dealer replaced the circuit breaker. All 15 amp fuses are fine.
Any thoughts?? Thank you!
Old May 12, 2018 | 03:00 PM
brcree's Avatar
brcree
Try the relay, mine was a hit and miss item. Worked sometimes and not others. Auto Zone about 9 bucks.
Old May 13, 2018 | 01:13 AM
hscic's Avatar
hscic
Are you saying no power when you turn the key? if so, be sure your ground connection on the frame is tight .
Old May 13, 2018 | 02:59 PM
jpkremers's Avatar
jpkremers
Stage II
I tried a new relay, and the ground connection is tight. No go unfortunately. Could it be a battery cable? Not sure where to go next.
Thanks again for all the ideas!
luvmypeis
Sep 25, 2017 05:45 PM
677
Electrical/Lighting/Alarm
Jul 23, 2016 05:40 AM
Kyle Ashlock
Mar 7, 2016 05:43 AM
trozenhorse
Jun 24, 2013 09:56 PM
79lowrider
Apr 27, 2010 09:01 AM
