92 project
Old Oct 20, 2005 | 12:45 AM
hotrodrobert's Avatar
hotrodrobert
Default 92 project
Got the sporty fired off.Won't idle & runs rough with choke.So I know that I need to rebuild carb.But the million $$ ??'s is were do I start.The is no wiring harneess got new 1 from centech great harness every wire has were it goes all over it.
My friend put in the points for now.What should I buy for the ignition system?It has nothing at all just the borrowed parts.I was thinking something like the accel single fire complete or crane hi 4 any suggestion would be very greatful.
It has no lights or the handbar controls.I got some new housings for it with the switches.When I put the screws in the housing do I need to add some blue loctite to the screws so they don't vibrate out?
Needs new tires I have the front 1 but need to buy the rear 1.The brakes don't look bad but since I need to replace the tires should I go ahead & replace the pads?
This bike needs so much TLC I really I'm so lost on which 1 of the small projects to get the major project finished.So as always thank you thank you in advance for all suggestion that I recieve from all you great harley fans.
Mikes145
Wheels/Tires
Jun 27, 2018 08:40 PM
Mebeebo
Northeast Tri-State Area
Feb 19, 2012 06:15 PM
tjbitt
Sep 23, 2011 03:12 PM
22B
Wheels/Tires
May 6, 2010 04:58 PM
TOEHEAD1966
Sep 5, 2008 07:22 PM
