Oil on engine fin
Old Jun 25, 2007 | 11:30 PM
brgtr3's Avatar
brgtr3
Default Oil on engine fin
So, as a non-technical person, why would one of my engine fins (about 6 up from the bottom) have oil on it, but not the others?
Any ideas as to cause, and/or solution? Best bet for cleaning it?
Thanks!
Keith
Old Jun 25, 2007 | 11:37 PM
seikan1's Avatar
seikan1
Default RE: Oil on engine fin
Probably blowing out of the air filter cover and onto it as you ride. It happens to MOST Sportsters from what I gather. I "fixed" mine by placing a rag inside the air filter cover to absorb the oil. Just check the oil often and change your rag often.
Old Jun 25, 2007 | 11:40 PM
brgtr3's Avatar
brgtr3
Ahh, that could be it indeed. I refilled the oil before a long weekend trip, and I may have put a tad bit too much in there. I'll try to clean 'er off, and keep an eye on it, and NOT fill it so high next time.
Thanks! Now Ican sleep at night knowing Charlene is AOK.
Old Jun 26, 2007 | 10:26 AM
saltlick's Avatar
saltlick
i thought oil on the fins meant a blown head gasket. You can clean it out with a Q-tip.
Old Jun 26, 2007 | 11:14 AM
sportymike02's Avatar
sportymike02
6th Gear
doesnt that defeat the purpose of your hi flow airbox? wouldn't a breather be a better choice? + there is no rag changing.
Old Jun 26, 2007 | 01:33 PM
1200c's Avatar
1200c
Where is it on the fin? Shine at light in there to make sure it isn't the head gasket.
Old Jun 26, 2007 | 08:37 PM
saltlick's Avatar
saltlick
i had that same problem with my CB550, oil on the fins the mechanic said it was a blown head gasket, you better make sure its not before chalking it up to too much oil.
Old Jun 27, 2007 | 07:54 AM
brgtr3's Avatar
brgtr3
Yikes! Idea of blown head gasket doesn't sound good. I'll look a little closer and see if I can tell. Now you're making Charlene worried!
rickpaul
Jul 29, 2018 11:03 AM
cfave
Apr 21, 2014 10:48 AM
steamybob
Jul 26, 2013 09:16 AM
hogdoc357
Mar 29, 2013 06:35 PM
stevja1
Exhaust System Topics
Jan 18, 2009 03:48 PM
