What size are the threaded bolts on my stock ignition coil.......the two that the pink and white/black wires from the ignition module connect too. Mine has the stock little L shaped boots that just push on, like mini spark plug boots, I would like to remove these and put a nut on the two wires onto the ignition coil.
Problem is the white wire is really loose.....ride bike sputters out and dies.....move that white wire a lil bit, runs fine. Gonna cut the stock L shaped boots off and connect with nuts. Size of these threads? I could just crimp the white connector tighter, but options are nice.
