Bike won't start!
Old Jun 30, 2018 | 09:59 PM
Pbenavidez360's Avatar
Pbenavidez360
Stage II
Default Bike won't start!
Alright guys bear with me, I am new to this s#!t. I have a 2005 sportster 883custom, and recently the rear blinker went out. Searched a few videos....said cool I can do this....this is what I did in order.... Before I started I removed the positive cable on battery, then replaced the wiring for the blinker and put it all back. Then for whatever reason I disconnected the ground from the battery (so now the battery is fully disconnected) Then I reconnected the ground then the positive put everything together and......nothing.....does not start. I realized after all this s#!t that there is a particular way to disconnect and reconnect the battery! What can I do to get my bike running again?
Old Jun 30, 2018 | 10:15 PM
Tupp's Avatar
Tupp
Did you manage to switch the cables or arc the battery some how? Also there is a big *** fuse inline with the piwer wire. Is that still good or has it blown?
Old Jun 30, 2018 | 10:27 PM
Pbenavidez360
Stage II
Did not switch cables they are exactly how they were. Fuse looks good. I am gonna look over everything again tomorrow as I am curious at the moment with the situation. I just dont understand what the hell happened.
Old Jun 30, 2018 | 10:45 PM
mmesa005's Avatar
mmesa005
Check your battery wires to ensure they are tight especially the ground wire from the battery to the frame. Also check the positive battery cable from the battery to the starter, again, check to ensure it's connected and tight. Next, check your 30 AMP Maxi Fuse and your 15 AMP IGN ignition fuses.
Is your bike stock or is it modded in some ways, electrical?
rich56
Electrical/Lighting/Alarm
21
May 11, 2020 07:14 AM
Jessica Sinclair
May 9, 2019 12:37 AM
mlrailguy
Aug 16, 2015 06:49 PM
Krazyshark
Ironhead
56
May 13, 2012 07:45 AM
bykeguy
Mar 19, 2008 06:31 AM
