They are simple oil filled gas shocks. If they aren't leaking, and the spring isn't broken, they are still good. With that said, oil will break down over time, and the spring will soften as well. They are not meant to be rebuilt.
Replacement is the best option if you are not satisfied with them.
This is really good information.. The springs are not soft and the shocks seem to be fine..
Satisfied,
Was only worried about the age of the shocks..
No leaks and everything seems to be as it should..
