Downshifting into 1st
[IMG]local://upfiles/28574/E44CCC637BC04092B3785AD2563C39FB.jpg[/IMG]
When my 08 883 arrives in Sept/Oct the dealer I am getting it from is about 2 hours away from home. Most of the roads are 110kph roads, should I run it at 110kph for the full ride or vary the speed or stay under a 100kph for most of the trip ??. Dont want to stuff it the first day.
Also should I change the oil after the ride home ???
Tripp
I would keep it in second, especially if it's an 883. The lower gearing in the 883 makes it just fine to 'bog' in second at that speed.[/align][/align]And playing with the throttle a little won't hurt the bike, even if it's not broke in all the way. Just make sure you don't get the engine too hot in the process.[/align][/align]What you're trying to do in a new engine during the break in period is to wear-in the new engine parts so that they are worn smooth and thus will produce less heat and friction. A new engine has newly honed cylinder walls that are all 'scratched up,' and this produces much more friction between the pistons and cylinders, and thus muchmore heat. Getting a new engine too hot can cause oil to 'glaze' and leave a very hard varnish type of residue that will make it much more difficult to wear-in your engine properly, so you want to keep the R's down and thus the heat down on the engine until it is worn-in completely.[/align][/align]Once your cylinders have all the honing worn off, they are then in a 'bearing' type of condition, meaning they are like a smooth bearing surface which will allow the pistons to move up and down in the cylinders much more easily and thus with less heat created. The cylinders will also begin tobe worn to the fit of the pistons rings, thus making a good seal between the two.[/align][/align]That's about all you're trying to do during the wear-in period, other than also wearing in other metal-to-metal surfaces like cam and lifters, etc.[/align][/align]500 to 1000 miles usually takes care of the wear-in (although sometimes it can take longer). You'll pretty much know when it's worn-in all the way by the drop in oil consumption and the engine feeling cooler and running with less vibration, tightnessand so forth. The oil will also stop getting as dark so easily as it does when the honing is wearing off into the oil. Pull your dipstick out and not only check the color of the oil during the wear-in period, but also the heat of it (feel the oil with your fingers), and also the 'grittiness' of it. When it's fullyworn-in, you should notice a notable change in all three. The oil won't look as dark, it won't feel as hot, and it won't feel as gritty (don't forget to change it after only a few hundred miles, then again at 500 miles, and at 1000 miles)[/align][/align]
[/align]
[/align][/align]
[/align][/align]
[/align]
The slower the better just as long as you don't bog it.
You also might want to think about pulling over and letting it cool off every once in awhile, if you think it's getting hot.
As for changing the oil when you get home, it wouldn't hurt. I would change it as recommended in your owners manual at least, and even more if you feel like it, but never less.
I used to try andchange oil and filterin new engines aroundat 100 miles; 250 miles; 500 miles; 1000 miles, at least.
And as for the helmet thing, I recently laid my bike down, and I can honestly say even though I'm in no way scared to get on it again, I will most likely be wearing one for a while. Probably during the summer months where it's hot and people don't pay as much attention and drive like idiots here in Phoenix. I don't like wearin it, but it's just safe for the time being.
One more consideration regarding shifting into first at a stop. I tend to leave the bike in neutral at a light/stop sign/etc. My thought being that, if I'm in first, and my hand slips off the clutch, I'm lurching into oncoming traffic. I realize that keeping the front brake applied should take care of this, but having the bike in neutral while waiting for a light feels safer to me. It's worked for me since about 1964, I think I'm going to stick with that system!
A lot of interesting advice here...thanks..
The way that I have always slowed to a stop on all of my bikes is to downshiftSMOOTHLY all the way to 2nd, minimizing wear on my brakes, until I get to about 10mph at which time you can tell that the engine/tranny is no longer slowing the bike down, then I shift into neutral and brake to a stop. I have had 4 bikes over the last 14 years and i have always gotton excellent mileage out of my brakes and tires and I've never had to replace an engine. Knock on wood. Just to clarify, I'm not bragging, just trying to help out!
