Front wheel Vibration
Old Oct 11, 2018 | 07:24 PM
david_kilmister's Avatar
david_kilmister
Stage III
Default Front wheel Vibration
Forty eight 2014; I changed recently both wheels, new rim strip and inner tubes, did get one inner tube oem, the strips are and wheels are as the handbook says, only but the front one instead of being scorcher 31" is Scorcher 32"; they are the same size 130/90B16. after the first ride I noted that the wheel "vibrates" when I am at the red ligths and the handle bar is straight, like up and down, and when I turn the handlebar going slow it tends to move or to stick to the side that I am turning and feels like "un balanced", According to the tire service guy, spoke rims are balanced and have a mark where you align the wheel and no need for balancing. I do not know what is going on
Old Oct 11, 2018 | 07:42 PM
Zateeva's Avatar
Zateeva
what kinda tires, not all are marked to match...........hic!
Old Oct 11, 2018 | 10:13 PM
08xl1200r's Avatar
08xl1200r
Wheel balance is only an issue at higher speeds, like freeway speed, so something else is going on...sound more like maybe the wheels were not installed right after the tire change.
Old Oct 12, 2018 | 12:10 AM
hscic's Avatar
hscic
What did you have (rim size and type) prior to installing new rims/tires? Not all wheels are the same width. Is it properly spaced and aligned? I agree with the previous post, wheel balance issues are normally felt at higher speeds.
Old Oct 14, 2018 | 07:54 AM
cHarley's Avatar
cHarley
FYI this is not a size measurement, it's a model number, the " symbol doesn't belong.
Old Oct 14, 2018 | 08:47 AM
grbrown's Avatar
grbrown
Lightbulb
David, it would be helpful if you took more care when writing your message and checked it before posting! Some of it doesn't make any sense to me. I suspect what you are telling us is that you have changed your tyres, not the wheels, and have used the same spec rear tyre and a Scorcher 32 front. You say the front wheel vibrates at red lights? You're not moving then, so neither wheel can vibrate! So give us some clues of what is going on, there's a good chap!
Old Oct 14, 2018 | 06:23 PM
ChromeSporty's Avatar
ChromeSporty
My front wheel vibrates while stopped at red lights as well. That's what I love about my sporty.
drinktothat421
Dec 1, 2016 06:03 AM
nottaway
Wheels/Tires
Aug 31, 2015 02:30 AM
FFeric
Jul 19, 2015 07:57 AM
BigDevil
Feb 2, 2013 11:15 AM
dlrshort
Wheels/Tires
Oct 2, 2010 07:26 PM
