Muffler removal
Old Oct 24, 2018 | 11:30 PM
Casper's Avatar
Casper
Default Muffler removal
Not new to Harley’s, but just bought a 2013 1200C sporty, stock exhaust. I was going t remove the mufflers and maybe knock out to plug inside the stock mufflers. Loosened to muffler clamps, removed the two bolts under them mufflers, but then it seams like the front and rear are attached to a crossover or equalizer of some sort. How do I remove this? Don’t have a service manual yet..figured there’s got to be a method to this, little help maybe?
hate to sound like an idiot about this, just don’t want to cause more problems doing something dumb...
thanks all.
Old Oct 25, 2018 | 02:04 AM
hscic's Avatar
hscic
I am assuming by "plug" inside the muffler, you mean the baffles. If so, you may want to check out DK Customs site on how to do it. You will need to cut off a section of the tapered section of the muffs. Probably best to install TTIs to reduce reversion.
Nonetheless, the mounting brackets for the slip-ons also serve as the crossovers for the exhaust system. Each slip-on has a crossover port on it. I believe 2014 and later, the ports were on the head pipes.
Old Oct 25, 2018 | 02:37 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
It will be necessary to remove the belt pulley cover and under there take out the bolts that hold the crossover pipe in place or at least loosen them to get the pipe to disengage with the rear muffler.
After removing the 2 bolts and the clip holding the rear muffler it is down to brute force and ignorance to twist and pull the muffler off.
The same then with the front one.
Old Oct 25, 2018 | 11:51 AM
bodysurfer's Avatar
bodysurfer
Just finished w swap back to stock mufflers on 2008 xl1200c. you need to removes headers to be able to lift slip ons off/on the crossover tube. Took me a full day, process exacerbated bc l couldnt find a wrench that fit my o2 sensors, so l left them on and tried to be really carefull not to pull on the wires when yanking/twisting on mufflers, both to remove them, and to realign exhaust w install. Even thogh l spent a long time getting the alignment right without yhe gaskets on to avoid damaging them while , it took still longer and was harder than expected to get the final alignment with the gaskets in place as the exhaust is essentially a single part.
used a lot of breakfree and several rest brakes to let it work. also ended up tieing headers to foot pegs and and other parts as needed to secure it when twisting/pulling to avoid bending or damaging them (hope so anyway, went back together ok anyway), rear pipe has a clamp that helps here that the front one doesnt.
Recc also that you get the 4 new gaskets before you start, use a file to really smooth the male/female openings, esp on the old mufflers, if a screwdriver was used to knock them off like mine were.
The hardest unexpected problem was inserting the new header gaskets, They need to go STRAIGHT in, and l had to do a lot of smoothing/burnishing and uncountable retries before l got them in straight and not deformed.
good luck and dont forget the easyout goop.
Old Oct 25, 2018 | 12:04 PM
HOTLAP's Avatar
HOTLAP
Wow, when I did my '07 I just undid the muffler bolts and removed the mufflers and installed the new ones, took about a half hour, I didn't have to touch the headers at all. The only difference between my '07 Roadster and your '08 custom is the forward controls on yours, maybe that makes a difference.
Old Oct 25, 2018 | 01:33 PM
bodysurfer's Avatar
bodysurfer
Alas that seems to be the story of my life hotlap, expected before l started to have it go like yours did. Admit l do need to get the manual, but l just got my bike too and .... lt just felt like l was putting too much pressure on the header to lift the pipe off the crossover tube, and the pipes were well stuck together despie a day of soaking in breakfree.
removing the header also allowd me to better position everything to better grip, twist, pull, etc... wo putting more stress on the tube,head joint, or wiring, particulary the front pipe, cause the rear pipe has a clamp u can use to secure the header when you twist. Was really getting nervous that the pipes would tear or distort before the they finally started moving, and rhat $40 used mufflers were going to need new headers before l was done.
as a bonus to removing the headers, in addition to really liking the better low speed performance l get low with stock vs the loud “race” pipes the po had put on, l discoved the head gaskets were mostly gone, flange nuts were little more than finger tight,and there was no sign of the crossover tube gaskets. Also seems to have cleared up a lot of my wierd idle issues, that weren’t responding to snake oil gas treatments or cleaning the IAC, that l’ve been trying to resolve via another thread.
Old Oct 25, 2018 | 01:40 PM
HOTLAP's Avatar
HOTLAP
Yes I did mine when the bike was only about 6 months old before corrosion was an issue, I can see it being an entirely different animal after 10 years of corrosion & rust.
Old Oct 25, 2018 | 09:17 PM
Casper's Avatar
Casper
Thanks all
Old Oct 26, 2018 | 04:09 AM
grbrown's Avatar
grbrown
Red face
I've dismantled the exhaust on my bike and, despite umpteen years of tinkering on bikes, had to resort to reading my FSM! To be frank it isn't a simple thing to describe, nor to do. Your '08 bike is the first year of that style of set-up, so previous models were different, indeed more recent Sporties are different again. The balance pipe also serves as the mounting bracket, which is a clever idea, if a bit complicated to mess with.....
Old Oct 26, 2018 | 10:26 AM
pistondealer's Avatar
pistondealer
If all you are going to do is remove the stock baffles don't bother taking the mufflers off the bike. It's super simple with the mufflers installed and probably easier.
A 2" hole saw will fit perfect inside the end of the muffler. You won't need the pilot on the hole saw the lip on the end of the muffler will center the hole saw. Cut thru and the inner baffle literally falls out. You won't cut any chrome on the outside or the end of the muffler so it looks clean and sounds good.
revriff
Nov 3, 2014 01:48 PM
trukintug
13
Apr 3, 2013 12:11 AM
odie-in-az
Jul 27, 2010 02:29 PM
gilmour68
Feb 20, 2009 08:44 PM
07 Fatty
Exhaust System Topics
Sep 20, 2007 09:55 AM
