biggest tires
Old Dec 4, 2018 | 04:14 PM
gerald martin's Avatar
gerald martin
Default biggest tires
what are the biggest tires I can put on my 2005 883 low
would a 180 mm fit on the back and would a 140-70-19 fit on the front
Old Dec 5, 2018 | 12:39 PM
mmesa005's Avatar
mmesa005
Aside from what others contribute here, there are many threads regarding tire/wheel conversions over at the XLForm http://xlforum.net/forums/showthread...180+rear+wheel
Old Dec 6, 2018 | 06:59 AM
misput's Avatar
misput
Measure from the inside edge of your belt to the widest point of your tire. Very little room.
Old Dec 6, 2018 | 07:48 AM
grbrown's Avatar
grbrown
Wink
We have several 200 and 180 threads in here, just take a look around. Here's one you should read through. Bear in mind that most tyres wider than 150 will require a wider than stock rim to fit the rear and quite probably up front as well.
Old Dec 6, 2018 | 08:14 AM
multihdrdr's Avatar
multihdrdr
Gerald, go look at your bike ... Do you think you can put a 40mm wider tire in your Narrowglide front-end (you have a 100 tire) ... even with removing the fender? ... No
You would need at least some Midglide Trees and a wider rim
On the Rear, your 1-1/8" belt will make it a little tougher (1" on 2007-later) ... of course you would also need a wider rim
Old Dec 6, 2018 | 10:28 AM
gerald martin
Thanks Guys
I think I will just leave it at what I have. I appreciate your remarks.
Gerald
Old Dec 7, 2018 | 04:50 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Hey Gerald,
Not sure you are wanting something like this, but these are some wide looking tires that fit on the stock wheels of our 48. Zero clearance issues.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Dec 7, 2018 | 07:26 PM
multihdrdr's Avatar
multihdrdr
Kevin ... he doesn't have a 48 (with Midglide forks and a 3" rim)
Old Dec 7, 2018 | 09:45 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Yes, I should have found a better pic. The tire on the front of that 48 is also the same tire that will fit on the back of his 883. I should have mentioned that in my post....I will try to find a photo of it from the rear, posted the photo I did to show it is pretty gnarly big and will fit the rear he was asking about. It is a Coker.
Old Dec 8, 2018 | 06:49 AM
multihdrdr's Avatar
multihdrdr
The Rear? ... It must be an illusion of being wider because those 5.00 Cokers spec out as narrower than his stock 150 ... and then what do you do with the front
SlimPaul
Jun 28, 2015 10:24 PM
Temporary Username 1
May 1, 2014 04:52 PM
Wide Glide 25
Apr 15, 2013 07:15 AM
hfp3030
Nov 8, 2012 05:21 PM
grimm
Dec 6, 2005 10:28 PM
