1200 customer not starting.
Old Dec 13, 2018 | 11:12 AM
Lane Mordja's Avatar
Lane Mordja
Stage I
Default 1200 customer not starting.
Need some input. I have a 98 sportster 1200 that wont start. The odometer reset itself, blinkers wont flash but do turn on, hazards flash, horn stopped working, wont crank, tried to push start with no luck. New battery, new voltage regulator. Any ideas?
Old Dec 13, 2018 | 11:45 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I don't know your bike but you have reeled off numerous electrical faults.
I would think starting with just getting the horn working would take you a long way to resolving the problem.
The fact the bike won't start I would think is the least of your worries.
Old Dec 14, 2018 | 07:33 AM
ajay1976's Avatar
ajay1976
I had the same problems - '88 XLH. This was due to a ground fault. You need to start by checking all connections. Good Luck.
Arnie
Old Dec 14, 2018 | 10:45 AM
hscic's Avatar
hscic
Sounds like you have different issues....I would start with fuse and connections. Horn stopped working and won't crank sound like a bad ground but could be other things....need to begin eliminating possibilities.
Since your TS turn on but do not flash but your hazards flash, perhaps a bad flasher relay for the TS if you have two flashers (one for TS and one for hazard). If you have only one flasher relay, then probably a different issue.
Old Dec 14, 2018 | 11:44 AM
Andy from Sandy
I am thinking it is a common issue as so much has stopped working. Seems like aj is on the case.
Old Dec 14, 2018 | 11:56 PM
VAFish's Avatar
VAFish
Check your ground cables, as I remember there are a couple (maybe even 3) of them on the 98 Sporty's. Not just the ground cable to the battery, check and clean where it attaches to the frame.
nukie
EVO
Apr 24, 2017 09:41 AM
Trettmeinsohn
Electrical/Lighting/Alarm
May 10, 2016 12:43 PM
mrmagoo420
Apr 13, 2014 04:23 PM
cjbmustang
May 9, 2011 09:56 PM
dazed.dnc
Jun 6, 2010 10:20 PM
