Bank Angle Sensor
Old Feb 10, 2019 | 06:08 AM
Spurlee's Avatar
Spurlee
Default Bank Angle Sensor
I'm finishing the wiring on my 1998 XL Custom based chopper. It cranked, started and ran perfectly with a broken BAS. The top portion of the BAS was broken off, the switch function was gone and just a small portion of a circuit board remained.
I bought a replacement one (P/N 32495-98) installed and oriented it correctly, I think - plug at the bottom, no?
With the new part it won't crank at all, no power to the starter. If I put the "broken" BAS back in it cranks fine.
I know to cycle the ignition to reset the BAS. Any thoughts?
Thank you!
Old Feb 10, 2019 | 02:15 PM
Nailz's Avatar
Nailz
Just a guess as its happened to me in the past....bad new part .
Good luck!
Old Feb 10, 2019 | 07:16 PM
Spurlee's Avatar
Spurlee
Default Bank Angle Resolved
I went back and reviewed my prior work and found a bad crimp in a connector termination that allowed an intermittent fault in the starter relay connection.
Issue resolved.
Old Feb 11, 2019 | 09:49 AM
MoneyFor's Avatar
MoneyFor
Glad you solved the problem, just weird that the "broken" part worked and the new one didn't.
Mercdwarf
Shovelhead
Sep 18, 2018 09:06 PM
wgb3470
20
May 18, 2015 07:18 AM
guitarman023
Aug 12, 2013 07:09 AM
o/d
Aug 14, 2011 01:09 PM
BOP21CG
May 12, 2007 06:58 PM
