Code: ECM PO113 Hist
Old Apr 6, 2019 | 10:35 PM
IronMan69's Avatar
IronMan69
Default Code: ECM PO113 Hist
Recently, I'm getting this code "ECM PO113 Hist" on my 2012 Iron 883 the code comes on and off. My bike will still start right up and I drive my bike often with no problem even the code still there, sometimes I clear the code with my DynoJet. But just yesterday another code came out again ECM PO113 Hist with "IAT sensor voltage open High/EFI". Now, I need help to locate and how to fix it.Thanks!
Old Apr 6, 2019 | 10:51 PM
HotRod917's Avatar
HotRod917
IAT = Intake Air Temperature sensor.
check the connection..remove n replug again
Old Apr 7, 2019 | 07:47 AM
IronMan69's Avatar
IronMan69
Thank you HotRod917! Today I will try to check the connection and if I need to removed that sensor and try to clean up and see if the code will disappear permanently. How do I know if the sensor is bad? Is there any way to test, maybe with multi meter? any idea? before replacing it. Thanks in advance!
Old Apr 7, 2019 | 01:22 PM
HotRod917's Avatar
HotRod917
No problem so yes basically test for continuity and voltage read with a multimeter at TMAP and wiring harness to the ECU. Also check wiring harness for any cracks and shorts.
heavymetalthunder
May 5, 2018 11:02 AM
TheMakani
Apr 29, 2015 05:58 PM
pat.h
Sep 6, 2014 06:05 PM
lkman111
Jul 27, 2008 07:36 PM
HDF Tech
General Topics/Tech Tips
Jul 21, 2005 10:41 AM
