883 not turning over???
Old Apr 7, 2019 | 05:52 PM
trike1946's Avatar
trike1946
6th Gear
Question 883 not turning over???
Hi all. My wife's 97 is not turning over. It ran about a month ago. Starter is about a year old. It has a new battery with 12.8 volts. All the lights and horn work. The starter relay clicks when I push the starter button. If I hit the kill switch it doesn't click. Using a multi meter it seems to have power at the two big terminals on the end of the starter. I think I can see a small wire at the bottom, maybe green, not sure. Is this the one that makes the power connect? Or what else could be wrong? I appreciate any help.
Old Apr 7, 2019 | 06:38 PM
VAFish's Avatar
VAFish
Can you bypass the solenoid and put power directly to the starter?
Could be a stuck or bad solenoid.
Old Apr 7, 2019 | 06:46 PM
trike1946's Avatar
trike1946
6th Gear
Thanks for the reply.
Jump from the battery to the large terminal on the starter, hot side?
Old Apr 9, 2019 | 06:05 PM
trike1946's Avatar
trike1946
6th Gear
Well the problem turned out to be the starter or solenoid or both. I jumped it and nothing. So I pulled it out. Not a fun job in the driveway. I had another used one in the garage. So I dug it out and put it in. It is not completely back together but it does turn over now.
Thanks for the help.
MotleySTL
EVO
11
Nov 22, 2024 04:49 PM
TheTurd
Jun 20, 2024 05:34 PM
shiznits75
May 20, 2010 12:33 PM
shiznits75
May 20, 2010 12:31 PM
wbogley
Shovelhead
Nov 28, 2007 09:42 PM
