Road King Shocks
Old Apr 14, 2019 | 11:50 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by handirifle
It's amazing what a few extra inches of travel can do for the ride. I am tempted to go from 12's to 14's on mine and get longer forks. I need to raise my bike 2" in my shop to see how well I can plant my feet before I do though.
Originally Posted by lewk
Are we still talking about shock absorbers??
hahaha, yep!
The best possible rear suspension on the Sporty is the 14" shocks WITH lowering blocks. This keeps it at the height of 13" shocks, & puts more leveraging on the shocks for improved articulation.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Apr 14, 2019 | 02:13 PM
handirifle's Avatar
handirifle
Lol yes I was at least. Reading this made me pull the trigger on a set off ebay. I got 13" ones for a bit more rear cush. Might add front fork extension later, will see.
Old Apr 15, 2019 | 05:32 AM
shanneba's Avatar
shanneba
Here is a FAQ on air shocks for Sportsters that may come in handy as you go to install them.
https://www.hdforums.com/forum/sport...sportster.html
Old Apr 15, 2019 | 12:09 PM
handirifle's Avatar
handirifle
Shanneba
Thanks for the link. Good info. Someone posted part of that link earlier and I actually used the shock part numbers to buy mine. Thanks
Old Apr 19, 2019 | 09:54 PM
handirifle's Avatar
handirifle
I finally got my RK shocks. The seller said new 5w oil in them. They came with hex screws in the air port, but has the quick connect fitting. Just for the record, I CAN ride them with the plugs in, correct?
Also I read somewhere, what size air line, but do not remember, and also seems like someone had a link for that sized "T" fitting. Does anyone have that link and line size?
Thanks in advance.
Old Apr 19, 2019 | 09:56 PM
handirifle's Avatar
handirifle
Originally Posted by DK Custom
hahaha, yep!
Would that setup give you more travel, or just changes the angle of engagement, to allow a softer ride?
Old Apr 21, 2019 | 06:09 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Thanks in advance.
Yes, no problem to ride with the hex screws in. There will not be any air pressure, but it will not hurt them.
Wish I could help with the size tubing and T fitting today. If you shoot an email and ask, I have both those at the shop and can get that info back to you tomorrow.
The 14" Max-Travel shocks have quite a bit more stroke than 13" touring take off shocks...so you would get more travel, the shocks are better, so better road compliance. The Lowering Blocks will keep the height of the seat the same with the 14" as if you were running the 13". btw, you can use the Lowering Blocks with your 13" air shocks and get the seat down a bit should you want it. Plus, the air shocks ride better with the improved angle they sit at with the LB's.
Old Apr 21, 2019 | 07:47 PM
handirifle's Avatar
handirifle
Ok thanks for the info. Most likely if I do not like the ride angle I will raise the front to match. These bikes are low enough for me. I don't want 31-32" seat height kinda thing, but hate scraping parts going over speed bumps, and a little more lean angle is always a good thing.
Old Apr 21, 2019 | 07:50 PM
handirifle's Avatar
handirifle
Oh and I THINK I found the size. I believe it's 5/32". I might just go with schreader valves and forget the lines. They are easy to reach even with the bags on.
KISS Keep It Simple Stupid. Thats what I used to say at work when training someone. Time to follow my own advice.
Old Apr 21, 2019 | 09:53 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I've always used the Schreader valves on mine. Easy, and works well.
