Engine knock
Old May 6, 2019 | 03:34 PM
Nick Palladino's Avatar
Nick Palladino
5th Gear
Default Engine knock
Just rebuilt top end of my 1994 sportster 1200. Runs great but knocking sound from engine. Cyclinders were bored and valves redone at machine shop. Knock is barely noticeable in neutral but when you put in gear and take of it gets worse. Any advice. Also noticed after only a few miles after rebuild oil in intake when I took off carb.
Old May 6, 2019 | 03:55 PM
HOTLAP's Avatar
HOTLAP
You sure you didn't mix up the push rods? they are different lengths.
Old May 6, 2019 | 03:58 PM
Nick Palladino
5th Gear
No the one with three stripes is closest to exhaust one stripe closest to intake.
Old May 6, 2019 | 04:07 PM
gerald martin's Avatar
gerald martin
read about taking pistons off on the hammer performance website. Mabey that's what happened to yours
Old May 6, 2019 | 04:09 PM
HOTLAP's Avatar
HOTLAP
Pick up a cheap stethoscope from harbour freight and see if you can pinpoint where the knock is coming from.
Old May 6, 2019 | 04:58 PM
Nick Palladino
5th Gear
did that sounds like front cylinder.
Old May 6, 2019 | 05:00 PM
Nick Palladino
5th Gear
I installed new pistons and rings
Old May 6, 2019 | 05:12 PM
HOTLAP's Avatar
HOTLAP
Maybe a wrist pin clip on the front piston not installed properly?
Nick Palladino
May 6, 2019 08:43 PM
raye321
Ironhead
Mar 29, 2015 11:02 PM
Krazyshark
Ironhead
Jan 23, 2012 07:51 PM
Stuart Dailly
Exhaust System Topics
Jul 30, 2010 08:23 AM
ardmorejoe23x
Jul 10, 2006 12:05 AM
