Ignition Switch or Kill Switch
Old Jul 9, 2007 | 09:45 PM
Dale Franks's Avatar
Dale Franks
Default RE: Ignition Switch or Kill Switch
Looks like we're all kil switch guys from the poll results.
Old Jul 9, 2007 | 09:48 PM
128auto's Avatar
128auto
I lock the brakes and pop the clutch to shut off the motor J/K
I use kill switch, it's easy.
Old Jul 9, 2007 | 10:03 PM
98XL1200C's Avatar
98XL1200C
Use it.......This is what my Owner's Manual has to say.
Engine Stop Switch
Engine stop switch is located on the right handlebar control. The engine stop switch turns ignition ON or OFF and should be used at all times to stop the engine, especially in an emergency.To stop engine, push switch to position marked OFF - then turn key to OFF.
Old Jul 9, 2007 | 10:11 PM
98XL1200C's Avatar
98XL1200C
Use it...this is what my Owner's Manual has to say
Engine Stop Switch is located on the right handlebar control. The engine stop switch turns ignition ON or OFF and should be used at all times to stop engine, especially in an emergency. To stop engine, push switch to position marked OFF - then turn key OFF.....Problem Solved.
Old Jul 9, 2007 | 10:13 PM
OldFenderGuy's Avatar
OldFenderGuy
It's another 'safety feature' that Harley has added to their bikes over the years.
Good to get in the habit of using it, as it's main purpose is an 'emergency shutoff' in case you run into problems. If you use it all the time it's position becomes second nature, and it something were to happen your thumb could click it to shut the bike down instantly.
When I had my Sportster I used it most of the time, mainly because of the reaching involved to get to the ignition switch which is mounted down in front of the bike.
On my Big Twins the ignition switch is mounted right in front of you on the tank, and it's a lever instead of a key. Because of that I normally just use the ignition lever, and seldom bother with the "kill switch".
Old Jul 9, 2007 | 10:29 PM
HighDesertKid's Avatar
HighDesertKid
Use the kill switch... Safest and best way to shut off your bike
Old Jul 10, 2007 | 08:13 AM
possum67's Avatar
possum67
ORIGINAL: HighDesertKid
Why is it the safest...I find myself leaving the ignition on and possibly killing the battery if I use the kill switch... I use ignition and pull the key...habit and I don't kill the battery...
Old Jul 10, 2007 | 08:52 AM
TheKingsOutlaw's Avatar
TheKingsOutlaw
I couldn't agree more!
TKO
Old Jul 10, 2007 | 09:58 AM
jterp's Avatar
jterp
ORIGINAL: possum67
Because you can turn the bike off without taking your hand off the brake.
Old Jul 10, 2007 | 04:01 PM
HOTLAP's Avatar
HOTLAP
ORIGINAL: possum67
I did exactly that one time, noticed before it completly drained the battery but have used the key ever since.
I always stop, put it in neutral, put the stand down, get off and walk around to the right side and shut the key off. (I just like to hear it idle a little longer)
