Battery tender?
Old May 23, 2019 | 03:10 PM
danjkav's Avatar
danjkav
4th Gear
Default Battery tender?
Hi,
New here! Hopeless mechanic, happy '10 Iron 883 owner, totally standard bike.
I've just managed to break the positive connection on the battery tender whilst reinstalling my battery.
Now the bike won't start, though it lights up like Vegas. No clicking when or turning over whatsoever. Do I need to replace that cable or is there something else wrong?
I thought that was just for charging?
Best regards,
Dan
Old May 23, 2019 | 03:15 PM
Jackie Paper's Avatar
Jackie Paper
Probably blew a fuse. Need some pictures.
Old May 23, 2019 | 03:18 PM
danjkav's Avatar
danjkav
4th Gear
Sure, but what of?
Sorry, other than change the battery, and check tyre pressure I only ride it!
Old May 23, 2019 | 03:25 PM
Midpegs's Avatar
Midpegs
Originally Posted by danjkav
Sure, but what of?
Then you are at the start of a long and interesting journey and at the bottom of a very steep learning curve . Good luck .
Old May 23, 2019 | 04:40 PM
hscic's Avatar
hscic
Not sure I understand what broke...is it the charging cable that is connected to the battery or the battery tender cable....or the positive cable on the battery.
I would check the fuses first and while you are at it, make sure all connection at the battery are secure then follow the battery cables (pos and neg) and tighten the other ends. If not the fuse, then might be a connection to your starter solenoid/coil since your get lights but starter not turning.
Have fun with it...it's a learning process.
Old May 23, 2019 | 04:50 PM
danjkav's Avatar
danjkav
4th Gear
Smile
I would check your fuse and while you are at it, make sure all connection at the battery are secure then follow the battery cables (pos and neg) and tighten the other ends. If not the fuse, then probably a connection to your starter solenoid/coil since your get lights but starter not turning.
Hey, thanks. It's the metal end of the tender cable which connects to the positive part of the battery, that bit snapped off. So it's all hooked up except the positive part of the tender cable.
I'll check the fuses.
But is the tender cable necessary to start/run the bike? I thought that was just to charge it.
I will order a new one for sure but would like to use the bike in the meantime.
Cheers for helping
Old May 23, 2019 | 04:59 PM
RANGER73's Avatar
RANGER73
The tender cable is just for charging the battery. Something else is wrong
Old May 23, 2019 | 05:01 PM
danjkav's Avatar
danjkav
4th Gear
Excellent! That's saved me some time messing around with that in the morning! Cheers.
Old May 23, 2019 | 05:02 PM
Jackie Paper
Cheers for helping
Why I wanted pictures of the wire. What you broke and where it went. An actual maintenance charger should have an inline fuse in it. I was thinking you may have actually broken a + lead for something else.
I can help you if I know for sure what you are talking about. You sure battery actually has 12.7 volts. It can still do lights and not throw in starter. Is bar off switch on? That is easy to forget. I never use it. My buddy likes to flip it on for me. If I use it, then I forget headlights. I flip off the key switch since it is not locked and hit the alarm. If I were to really leave it like when I use to work, I lock bars and key switch.
Old May 23, 2019 | 05:05 PM
Iceman24's Avatar
Iceman24
^^^YEP^^^
The cable probably shorted out on something metal and blew a fuse...pics would definitely help (of the battery terminal).
