Difficulties shifting into neutral
Old Jun 17, 2019 | 10:15 AM
Pfarley1's Avatar
Pfarley1
Default Difficulties shifting into neutral
I can barely, if ever get my bike to shift into neutral when the bike is at a stand-still. I try moving the bike a little, which helps make it easier to shift, but still usually it shifts into second. Even shifting into second at a complete stop is pretty difficult.
Is there anything that I can do to make it easier to shift into neutral when the bike isn't moving?
I have a 91 Sportster 1200.
Old Jun 17, 2019 | 10:47 AM
Katestra's Avatar
Katestra
2nd Gear
Any info on the spring plate?
Old Jun 17, 2019 | 11:56 AM
whylee's Avatar
whylee
Mine does the same thing , trying to find neutal while the bike is running is a act of frustration. Once its off, its alittle easier.
Old Jun 17, 2019 | 07:43 PM
LordSargon's Avatar
LordSargon
I found it easier to use the Tarsus part of my foot than the toe to find neutral. Lifts it up just enough to find that sweet spot 90% the time.
Old Jun 17, 2019 | 07:55 PM
hairymoth's Avatar
hairymoth
Find a hot looking woman standing at a traffic light. When you pull away, you'd find N every time!
Old Jun 17, 2019 | 10:24 PM
kejobe09's Avatar
kejobe09
Have you adjusted the clutch? If not try that first. If so, double check the adjustment to make sure it was done correctly. Have you adjusted the position of the sift linkage? The part that connects to the shaft. Has this just started? Or has it been an issue since you've had the bike? How long has it been doing it?
Forgot to add, FWIW, I don't have any issue finding N on mine.
Old Jun 17, 2019 | 10:27 PM
kejobe09's Avatar
kejobe09
Old Jun 18, 2019 | 01:44 AM
1Qcktrufflesnuffler's Avatar
1Qcktrufflesnuffler
The best technique I've found is as you're approaching the stop light/sign, parking spot or gas pump and your coming down through the gears, stop at 2nd, slide your foot forward a little, and step down like your stepping on an eggshell and hopefully that neutral light comes on just before you have to put your foot down.
I've Sat at long lights going from 1st to 2nd, back to 1st and just given up and sat with the clutch in LOL.
Old Jun 18, 2019 | 10:16 AM
TStephen's Avatar
TStephen
Likewise, then I go to take off, and miraculously it's in neutral.
Old Jun 18, 2019 | 09:34 PM
ahappydude's Avatar
ahappydude
Not a mechanic, but I agree with a clutch adjustment. My bike has no probs finding neutral.
