Running light modual installed
Old Jul 13, 2007 | 04:31 PM
cHarley's Avatar
cHarley
Default RE: Running light modual installed
The 07 isn't much different in that respect. The 04-06 have an ICM in the same location instead of the ECM. You just install it under the ECM.
Old Jul 13, 2007 | 05:21 PM
kawsakimx6's Avatar
kawsakimx6
yeah mine had it when i bought it. I love it
Old Jul 13, 2007 | 06:35 PM
thomasf59's Avatar
thomasf59
Under my ECM there is nothing it would have to be installed under the plastic that the ECM sits on and that would be putting it above the rear tire.
Unless I position it on the plastic that the ECM snaps into and, let the ECM rattle around on top the light module, but that can't be good,what do ya think?
Tom
Old Sep 15, 2007 | 06:29 PM
hywy2hl's Avatar
hywy2hl
Anyone have the HD part # on that module?
Old Sep 15, 2007 | 06:37 PM
hywy2hl's Avatar
hywy2hl
oh forget it, I found it. It's 69463-06 for those looking too.
Old Sep 15, 2007 | 07:21 PM
128auto's Avatar
128auto
I just noticed that my right brake light turns off slightly slower than the left brake light, anyone? Give it a try
Old Sep 15, 2007 | 10:08 PM
hogsport's Avatar
hogsport
So no rewiring, just replacing a module and the lenses? With dark coming earilier that sounds like a must do.
Old Sep 15, 2007 | 10:32 PM
128auto's Avatar
128auto
Yes, you add the module to the wiring harness under the seat, same rear turn signal light bulbs but red lenses.
ORIGINAL: hogsport
Old Sep 15, 2007 | 10:51 PM
HarleyScuba's Avatar
HarleyScuba
Where to put the Run/Brake/Turnsignal module:
The red box is the light module. The green square is one half of the original plug. Yellow is the other half. The blue dot is a small bit of the wire running under the electric module and goes to the light module. You take thenuts off and lift up the electric module and tuck/coax the wires in place. No wires are pinched, bound,or twisted and run straight out of the light module (so there's no stress on the connection). Get all the stuff in a comfortable position and zip-tie it in place.
The hardest part of the job is taking the seat off.
clap
Feb 12, 2017 02:20 PM
Bubbak
2014-2024 Touring Models
Dec 20, 2015 03:46 PM
moparbobby
Jan 24, 2013 09:36 PM
yuma
Dec 27, 2007 05:45 PM
MANCHU DOG7
Jul 12, 2007 03:48 PM
