Running light modual installed
Old Jul 11, 2007 | 07:38 PM
utz's Avatar
utz
Default Running light modual installed
Wow what a difference that thing really lights up nice.Best 54.00 mod yet.
Old Jul 11, 2007 | 08:23 PM
Dale Franks's Avatar
Dale Franks
Default RE: Running light modual installed
I ordered one, too. it's still on back-order, though.
Old Jul 12, 2007 | 05:23 AM
kardoc's Avatar
kardoc
i concur Utz, looks like night & day.
Old Jul 12, 2007 | 01:43 PM
ontcanuck's Avatar
ontcanuck
Dale where did you get thet nice bag its exactly what I was looking for
Old Jul 13, 2007 | 10:25 AM
Dale Franks
Its a Harley bag I got at the dealership. It's the canvas overnight bag. "Sac by Harley Davidson".
Old Jul 13, 2007 | 11:05 AM
way2slo's Avatar
way2slo
You bet, best investment.
Old Jul 13, 2007 | 03:42 PM
thomasf59's Avatar
thomasf59
What do you mean when you say Running light Module my headlight and tail light are on when the bike is running.
Tom
Old Jul 13, 2007 | 03:55 PM
Earnie1200C's Avatar
Earnie1200C
I would agree. Definitely makes a huge difference. I installed mine on Tuesday along with the pig tail for the Battery Tender. I removed the module under the seat and slipped the light module under the factory wiring harness and into an open area in front of the rear fender and under the frame. Connected the two connectors, replaced the module and seat and all done. It took longer to do the battery tender pig tail than the light module did. I need to pick up a Torx T-47 bit so I can move the front turn signals down on to the lower front fork tubes. Then maybe some LED replacement bulbs to make everything even more visible to others.
Old Jul 13, 2007 | 04:11 PM
cHarley's Avatar
cHarley
ORIGINAL: thomasf59
Tom
It's a run/brake/turn module from HD for $54. First it replaces the rear amber turn lenses with red ones. Next after installing the module, all 3 rear lights function as run & brake lights. The left & right signal lights continue to function as turn signals.
Old Jul 13, 2007 | 04:20 PM
thomasf59's Avatar
thomasf59
I thought that was what the post was about but I wasn't sure, I would like to install that on my 07 but not sure there is room, I would have to see the size of the module and then see if there is room, not sure if a 06 is the same as a 07 as the 06 is carbed and there is not a ECM module, is there.
Pictures make a big difference.
Thanks
Tom
