How do I install Muffler interconnect bracket??
Old Jul 17, 2019 | 04:38 PM
Blackswan77's Avatar
Blackswan77
Default How do I install Muffler interconnect bracket??
The prior owner of my 2006 Sportster removed the muffler interconnect bracket. I got another one and it should be a simple install but it appears as though the rear brake tie rod has to go threw it. If this is the case how do I remove one end of that tie rod? The rear portion has a small pin that can be removed but that still leaves a very large pin that doesn’t seem to be able to be removed. Is there an easier way, perhaps removing the brake pedal??
Old Jul 18, 2019 | 11:50 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Yes the brake rod needs to come off at the back to get the bracket in position for the screws that hold the interconnect bracket to the crankcase.
That rose joint / screw is a torx T30. You can leave the rod connected at the lever end.
The pin with retaining ring is for the cylinder push rod and doesn't need to be touched.
That all looks to be a very clean 2006 bike.
Old Jul 19, 2019 | 11:40 PM
handirifle's Avatar
handirifle
Ya need to chill out a bit before starting. Looks like you're gonna bite your lower lip off.
Old Jul 20, 2019 | 05:45 AM
Blackswan77
LOL, I definitely needed two beers before starting. Did that the next day and got all the work done easy.
Old Jul 20, 2019 | 05:46 AM
Blackswan77
Thanks much! Yeah Im trying to keep it clean and restore parts to it where they were removed.
BobbyT
Aug 4, 2021 06:59 AM
shekmark
Aug 5, 2016 03:53 PM
Heisenbucks
Exhaust System Topics
Jun 2, 2016 12:37 AM
hOtroDD77
Oct 20, 2013 12:21 AM
jamc1103
Dec 15, 2012 04:17 PM
